Mopar R/T heads
Old Jul 28, 2010 | 10:10 PM
  #21
BigRedRam95's Avatar
BigRedRam95
Originally Posted by CPTAFW163
depends on the porting done. But those are some good numbers. Need to match them with a cam and intake though. THose are race flow numbers for high RPM powerbands.
Do you think my heads I got will flow enough for this cam http://www.compperformancegroupstore...=LACAMRFHRXECC
my truck is just a street truck so heads should be ok right
Old Jul 28, 2010 | 10:55 PM
  #22
CPTAFW163's Avatar
CPTAFW163
Stock RT heads will be GREAT with that cam. The specs on them are pretty much the same as the KRC RV cam:
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
But since KRC is no longer in business, this cam has the same specs:
http://stores.hi-potek.com/-strse-13...ter/Detail.bok
The owner of that company is a member of this forum. Rich.
Old Jul 28, 2010 | 11:34 PM
  #23
BigRedRam95
Do you think I will see some power out of that cam
Old Jul 29, 2010 | 01:11 AM
  #24
nopower318's Avatar
nopower318
This is gunna be one sick little truck when your done. Good luck!
Old Jul 29, 2010 | 01:19 AM
  #25
FarmBoy428's Avatar
FarmBoy428
Oh, hell yeah u can see power outa them. U will notice it when ur offroad, or just at a red light and punch it when it turns green. either or, what ever you do upgrades wise will ad power... Good Luck with the heads.
Old Jul 29, 2010 | 08:21 AM
  #26
stands2p's Avatar
stands2p
congrates on the heads.thats a steal imo.i would widdle on them alittle to get flow rates up.out of the box the castings rough but they clean up nicely and flow well for an iron head.stock heads are good to 400 crank but they crack.these are the factory's next level up from that.good luck
Old Jul 29, 2010 | 10:44 AM
  #27
aim4squirrels's Avatar
aim4squirrels
Originally Posted by lastrights
you should throw some 1.7 HS on those
aim i was curius whats good heads too run with the 1.7 and what reccomended on pushrods ext for my 5.9 im kinda going to the route you are with the stock cam just trying to make it a beefy DD. im looking to do heads and the airgap and be done ?
I totally forgot to answer your head question
The 5.9 magnum has less lift than the 5.2. .410 at the intake. With 1.7 rockers, that's around .436 lift. Heads that Flow really well in that area would be optimal, whether they be 2.02 Valves or 1.92 valves. Whatever flows best around low to max lift. It doesn't matter if they flow great at .550 or .600 because your valves will never see that.
You have long tubes, so that should be great for scavenging, so flow at low lift is important. Make sure the heads get at least a 3 angle valve job and I'd ask for "racing" valves that have had the base of the stem shaved a bit for max flow down low.
Old Jul 29, 2010 | 09:04 PM
  #28
BigRedRam95
how much do you guys think a valve job should cost? I got a quote for 150 a side I thought that was kinda high. What do you think?
Old Jul 29, 2010 | 09:22 PM
  #29
What all are they doing for the 150 bucks?
Old Jul 29, 2010 | 09:39 PM
  #30
BigRedRam95
Its 150x2 its per side complete rebuild is what he told me. I called another shop and they said 150 total for both heads complete rebuild
