Mopar R/T heads
Old Jul 29, 2010 | 09:42 PM
  #31
FarmBoy428's Avatar
FarmBoy428
go with the cheapest one if your low on cash, but if u got money, go to the expensive one.
Old Jul 29, 2010 | 09:50 PM
  #32
Originally Posted by BigRedRam95
Its 150x2 its per side complete rebuild is what he told me. I called another shop and they said 150 total for both heads complete rebuild
150 for both sounds more reasonable...... unless they are going to gold plate them for you as well?
Old Jul 29, 2010 | 09:55 PM
  #33
BigRedRam95's Avatar
BigRedRam95
I wish I could find someone to port them for me.
Old Jul 29, 2010 | 10:14 PM
  #34
aim4squirrels's Avatar
aim4squirrels
You'll pay way more than 150 for porting.
Old Jul 29, 2010 | 10:18 PM
  #35
BigRedRam95
I know its expensive but how much would it cost for some mild porting?
Old Jul 30, 2010 | 09:10 AM
  #36
aim4squirrels
Define mild.
Go to the Hughes site and check the difference between bare heads and ones with mild porting.
Subtract about a hundred bucks for taking them off the engine and pulling them apart yourself.
Old Dec 20, 2010 | 08:42 PM
  #37
BigRedRam95
Sorry to dig this back up but didn't want to start a new post. I am going to pull the intake and heads as soon as I can get my truck in the garage. Can I use stock replacement valve-train with the R/T heads? Also I am going with this cam http://www.compcams.com/Company/CC/c...?csid=659&sb=2 how do I know what length push rods to get will the stock length work.
Old Dec 20, 2010 | 10:20 PM
  #38
Well, the notes say stock springs can't be used. Doesn't mention anything else. Most of the links to 'suggested' parts don't work either, so, no data is available on them.
Looking at the cam, and comparing it to stock... there really isn't much difference. (of course, that doesn't take into account ramp rates, and various other ****ling things like that....) Might be better off just going with 1.7 roller rockers. accomplish pretty much the same thing, without the need to replace a bunch of other parts.
Old Dec 20, 2010 | 10:34 PM
  #39
BigRedRam95
wonder if I could do both? I don't know if I would have the clearance.
Old Dec 20, 2010 | 10:43 PM
  #40
The new cam DOES have higher lift than stock. (.480 with I assume the stock 1.6 ratio rockers.) so, the stock springs certainly would not work. Might have to do some clearancing on the valve guides as well. Just wouldn't do for the retainers to meet the tops of the guides, that would be...... messy.
You working on a 318, or 360?
