cooling mod for the 408
#42
If installed and treated properly, an electronic device will last much longer than an equivalent mechanical device, simply because the mechanical device relies on moving parts, where as the electrical device relies on electrical connections. Electrical connections, if not for outside forces (air/environment/moisture/vibration/whatever), would last forever. Mechanical devices will not.
#43
#44
Oh yes. On the electronic 4x4 I wholeheartedly agree with you. The control module, and the actuator motor on the t-case were flipping famous for failing. And at 300 plus bucks a pop..... Nope. Give me the stick on the floor every time. That was a crappy system when it first came out, and it hasn't gotten any better.
#45
[QUOTE=jbomb;2217486]Still waiting for the cam to arrive. [QUOTE]
Anyone who is needing a Magnum cam for a special grind is waiting. I supposedly had one coming almost two months ago. After a two week wait they called back to the shop and said that they are back ordered on Magnum cam cores. Aug 1st was the projected date for them to have cores to ship out. Tried all the top companies all waiting.
#46
#48
Don't forget, you get what you pay for...And some high-end e-fan kits come with a temp probe that goes in the radiator. Those work correctly as they should.
#49
If you get fans with a temp probe be carefull how/where you mount it.
My Flexilite fans supplied the probe & on temp adjuster.
They wanted(in 01) the probe inside the upper rad hose/neck.(not sure if they still suggest that)
Nothing but issues with it installed as suggested (pic below bit hard to see) so dont put it there!!!
The probe worked great, fans came on as set.
Problem was couldnt tighten the clamp too much or risk crushing the hollow tube going to the probe.
Too loose & it would leak as well as the hose would slowly move farther off the neck.
Going WOT & taking it close to or above stock redline was risky.
After 2nd time blowing the hose off(constantly adjusting hose & clamp) I yanked the probe out.
Put it in the location below to test to see how it worked (perfect/just change the on setting)
Moved the probe to the bottom of the rad after confirming it worked correctly.
