latest project: ram air hat
#21
#23
looks good.square peg in a round hole.the plastic scoops dont fit on the air cleaner?to big/wide maybe.homedepot HVAC section and hot water heater(smaller dia pipe) section both have stack boots iirc.this is the one iam running with heat duck and scoops.
http://www.schmidtmotorworks.com/pro...r_cleaner.html
#24
No the scoops and tubes are all the stock pieces from the Dakota, they just don't seal tightly. I'm looking to see if I can force all that on-rushing air down the TB, without letting it escape.
As the truck determines fuel trims and injector pulsewidth by air temps and density, I'm trying to push as much air into the TB as possible.
#28
#29
The only way that you can get the correct tune for this mod is to send hemifever your A/F ratio at WOT on the highway at 70 MPH. ANd you need a wideband A/F gauge to do that. THis is coming from hemifever.
I really want to do this, but I think it might be hard to find the Air Hats. Well, maybe not. Here in Arkansas, people drive lots of Daks. But finding an air hat that is in that good condition is next to impossible.
--Dan
