just replaced 46rh tranny. now it wont shift out of 2nd
Old 08-14-2010 | 07:21 PM
andy_s273's Avatar
andy_s273
i put 5 brand new quarts of atf+4. i just swapped it in. the fluids fine lol im scared to bust that 4500 rpm manuvre
Old 08-14-2010 | 07:23 PM
95RAM360's Avatar
95RAM360
it wont hurt it to do it once and a while...i remember a thread here a while back saying that its not good to baby these trucks, that you need to give them some sometimes...and 5 qts isnt enough....when i flushed i had to put 7 1/2 in each time....and thats with just dropping the pan....
Old 08-14-2010 | 07:24 PM
5 quarts in a rebuilt trans? It holds around 12 or so ya know......
Old 08-14-2010 | 07:56 PM
andy_s273's Avatar
andy_s273
oh wow i feel stupid let me check.. well im low by maybe 2 quarts.... is it bad to mix atf4 with generic stuff im desperate now
Old 08-14-2010 | 10:29 PM
xjarhead69's Avatar
xjarhead69
Use ATF +4 ONLY! in your tranny.
Dave
Old 08-14-2010 | 11:33 PM
techmike's Avatar
techmike
^^ What he said...
It's obvious once you have the trans open whether or not the owner used ATF+4.
Old 12-08-2017 | 03:50 AM
85 dodge D150's Avatar
85 dodge D150
i have 46rh transmission in 85 dodge D150 and it wont shift into 3rd
Old 12-08-2017 | 11:21 AM
Check fluid level. (in neutral) Whens the last time the trans was serviced?
Old 12-12-2017 | 03:56 PM
85 dodge D150
i haven't did it yet but i just bought transmission gasket and filter for it today.. what angle should my transmission be at, because im put 46rh transmission in 85 D150 and i had to make crossmember
Old 12-13-2017 | 01:14 PM
Should point down toward the rear diff a few degrees. If you don't get a vibration while driving, it's fine.
Quick Reply: just replaced 46rh tranny. now it wont shift out of 2nd
