Rough Idle
Old Aug 14, 2010 | 09:10 PM
losi8ight's Avatar
losi8ight
Default Rough Idle
I have a 2001 dodge ram 5.2 1500 that has this weird idle goin on. It doesnt sound like a lifter or rod its just a ruff idle. It will do it up until about 15mph then its fine. The weirdest part is you can here it a lot louder inside the truck then outside. I dont know whats goin on but any input would be greatly appreciated! Thank you.
Old Aug 14, 2010 | 10:43 PM
Scottr1110's Avatar
Scottr1110
you got a check engine light. does it do it in drive only or in park as well
Old Aug 14, 2010 | 11:45 PM
losi8ight's Avatar
losi8ight
Yes I have a check engine light on but thats only been on there for about a week. Its been running rough for at least 2 or 3 months and it does it in park and drive. Also at about 65 mph the rpm's will shoot up about 200rpms randomly then go back to normal.
Old Aug 14, 2010 | 11:59 PM
losi8ight's Avatar
losi8ight
I wonder if it mite be a EGR valve or something like that. Theres no metal hitting metal sound.
Old Aug 15, 2010 | 12:00 AM
Scottr1110's Avatar
Scottr1110
get the check engine light checked out sounds like u might have a missfire did the check engine start flashing and then stay on when it came on
Old Aug 15, 2010 | 01:19 AM
jasonw's Avatar
jasonw
Site Moderator
My bet is a bad TPS. TPS can mess with the idle, and when at high speeds (especially if using cruise control) your RPMs randomly jumping up and down about like yours are also tells me TPS. If the voltage from the TPS gets out-of-spec enough, it will trigger a code from the PCM.
Get that code checked out at O'Reillys, Advance, or etc., anyone who will read it for free.
Old Aug 15, 2010 | 09:11 AM
losi8ight's Avatar
losi8ight
The engine light doesnt flash oe anything it just comes on. Today im gonna go to autozone and have them test it and see what they come up. Thanks for all the input! Ill let you know how it comes out.
Old Aug 15, 2010 | 05:47 PM
losi8ight's Avatar
losi8ight
i went to autozone and they said the check engine light means that there is a small leak allowing gas fumes to escape. we checked the pvc valve and it seems to be alright. i kinda wonder if its the EGR valve but thats 60 bucks. so before i buy that does anybody have any suggestions? thank you
Old Aug 15, 2010 | 05:57 PM
gas fumes are EVAP system. Could be as simple as the gas cap not being on tight.
Old Aug 15, 2010 | 09:42 PM
J415's Avatar
J415
What code specifically did you get? Have them tell you and we can diagnose it a little better.
