think my plenum crapped the bed again :(
Old Sep 9, 2010 | 07:46 PM
lastrights's Avatar
lastrights
Default think my plenum crapped the bed again :(
the 1st owner says he did it, and right now my truck is running like a pig bad idle also, not running like it used to , and now im getting bad spark knock.. im thinking my plenum crapped the bed again, the guy before me prob used the same plate. so here is my deal
im wantting the airgap, but i think with the mods i have in my sig i think i can maybe support the m1 , but im really lost on what to order, like M1 wise ?2 0r 4 barrle,throttle body adapter,fuel rails, what all do i have to order to make this work , and would it really come out to be cheaper than the airgap...
or should i just order a plate and call it a day , right now i just cant afford anything, i may just switch in some new plugs and see if that works . '
Old Sep 9, 2010 | 07:50 PM
Get the plate, and associated hardware, and call it a day. (verify that it is indeed blown first.....)
If whomever did the job last time just changed the gasket, and reused everything else, they didn't fix anything.
Old Sep 9, 2010 | 07:54 PM
lastrights's Avatar
lastrights
last time i checked it was notblown i will check , but its just running horrible right now, i may/hope just need to change my plugs, what champ plugs run the best in the 5.9...
right now i currently running ngk iridiums possibly 6000 miles on them
Old Sep 9, 2010 | 08:19 PM
Ram_Me's Avatar
Ram_Me
You could also do that mod on the manifold runners while you're in there.
Old Sep 9, 2010 | 08:22 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Turn down the tuner and get over it.
Old Sep 9, 2010 | 08:36 PM
lastrights's Avatar
lastrights
the tuner is set at 91 wise @ss, and it will still do it when its stock setting
Old Sep 9, 2010 | 08:49 PM
dodge15004x45.9
Ok dumb ***. Sound like someone needs break lines more than an air gap. That thing is an OVERPRICE pice of aluminum.
Old Sep 9, 2010 | 09:48 PM
Ram_Me's Avatar
Ram_Me
Let's concentrate on the problem. Check the plenum, and we"ll go from there.
Old Sep 9, 2010 | 10:27 PM
95RAM360's Avatar
95RAM360
yes get the plate, and do the kegger mod....thats what i did, and also bring the manifold to a machine shop and have them clean it....i had mine looking brand new inside and out for 40 bucks....not a bad deal when you see how much better it will run...
this is what mine looked like after i got it back from the machine shop...before i did kegger mod.....if anyone remembers i broke my camera before i could get pics of kegger mod
trust me, getting it cleaned made a difference, i can tell it runs cleaner....hard to explain
Old Sep 9, 2010 | 10:38 PM
Ram_Me's Avatar
Ram_Me
If I was you, I'd cut it first, then get it cleaned. Then you would be sure there's no metal shavings or anything else stuck in there.
