what do i need for plug change
Old Sep 11, 2010 | 05:04 PM
lane's Avatar
lane
better to watch your buddy do it than pay a mechanic...
Old Sep 11, 2010 | 05:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Well, I would say it's better to actually HELP your buddy! Unless of course money is no object.
Old Sep 11, 2010 | 06:23 PM
aim4squirrels's Avatar
aim4squirrels
I like the spark plug socket that is magnetic.
The rubber boot in the standard socket tends to stick the plug sometimes and pull out of the socket.
I highly doubt the plugs are causing the noise you hear unless one has failed.
Old Sep 11, 2010 | 06:42 PM
lastrights's Avatar
lastrights
what would be causing the click, my rings ? my idle is crappy also, i wanted to do tps and map but i really just dont want to be buying parts
Old Sep 11, 2010 | 07:02 PM
aim4squirrels
I'd guess by what you described in the other thread an exhaust leak.
It could be a plug, but I'd just buy one NGK and pull them all and inspect em. If you have one broken one, replace it, if not return the plug.
Those iridiums are good plugs and will run just as good if not better than the champions. And you don't need a colder plug until you make about 100 HP over stock. Too cold and it'll just foul more quickly.
Old Sep 11, 2010 | 07:03 PM
aim4squirrels
A bad injector can click loudly too.
Old Sep 11, 2010 | 07:37 PM
zje400ex's Avatar
zje400ex
Has the plenum been repaired?
Check engine light on? If so, what codes?
Have you rerouted your spark plug wires?
If you don't have tools. I recommond getting a small craftsman tool set. Sears will usually have some on sale every now and then. Can get a nice set for under $150
Old Sep 11, 2010 | 08:02 PM
lastrights's Avatar
lastrights
i have a 84 peice set craftsman .
plenum is good last time i checked
no engine light just bad idle and click when accelerating
thats interesting about the injector,that could be an idea thanks for the help guys !!
Might be a plug wire arcing too...... they make a rather interesting noise.
Old Sep 11, 2010 | 08:08 PM
lastrights's Avatar
lastrights
whats wire arcing ?
