Look What I found in my Diff.
Old Sep 12, 2010 | 02:09 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Default Look What I found in my Diff.
opinions? let it develop?. 130,000 miles and royal purple with friction modifier. I put the modifier in there even though the royal purple said it didnt need it, just for insurance . or did it affect the oil putting it in??Has been in there about the last 55,000 miles, yeah i know its a little long to go for oil changes.the oil didnt seem all that bad or smell burnt when i dumped it. just the small pieces stuck to the magnet.
Old Sep 12, 2010 | 02:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Looks like pieces from the clutch pack
Old Sep 12, 2010 | 02:59 PM
DukesOfHazzard
So when it grenade's itself, whats the best upgrade for us? A Daily driver, weekend warrior/hunter. really hard on the ole truck on the weekends getting to and from hunting spots. I read a quote from someone about ," i dont slow down for speedbumps , they slow down for me", lol similiar but i baja 1000 the truck up and down the rocky roads. no time for taking it slow.
Old Sep 12, 2010 | 03:07 PM
zman17's Avatar
zman17
Do a search here. There are a couple options like an Auburn diff for instance. This is a topic that is frequently discussed.
Old Sep 12, 2010 | 04:00 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Detroit!
Old Sep 12, 2010 | 04:43 PM
aim4squirrels's Avatar
aim4squirrels
Did you make sure that the gear teeth themselves were not broken up?
If no, then definitely the factory Trac-Lok system. The metal clutch bands break up quite easily. If you look into the pumpkin up on the drivers side near where the axle tube starts you'll see the clutch pack and it's more than likely broken. When you get the work done, you may want to consider doing gears at the same time if you want to go for a bigger ratio. It'll be expensive, but it'll save you some labor charge later should you decide to swap gears.
This was actually my first expensive "mod" back about 43,000 miles ago. Went with a Detriot Truetrac LSD and haven't looked back.
Old Sep 12, 2010 | 06:28 PM
dodge15004x45.9
It can be quite expensive.
Old Sep 12, 2010 | 06:34 PM
Laramie1997's Avatar
Laramie1997
I don't know the history of the truck, but I'm just throwing this out there....
If the previous owner had the rear end rebuilt at some point, that could have been left over shrapnel. I know that when mine went boom, it left a lot of crap behind that you can neither reach or flush out. I've just been extra careful when I change the fluid in the pumpkin that I inspect everything to make sure that the pieces parts I'm finding are NOT new.
Yea, I'm trying to be Mr. Optimistic here, but you never know.
Old Sep 12, 2010 | 06:40 PM
DukesOfHazzard
here's looking at thru the top drivers side looks like one of the "ears" (i dunno what its called) the clutch pack is shifted out of its place?
Old Sep 12, 2010 | 06:44 PM
DukesOfHazzard
and heres looking at the same ecept thru the bottom, ive owned since 75,000 miles and changed the gear oil once with royal purple first metal anything ive seen in the rearend. i think a combo of tharashing on it and letting it go a tad to long....and also the outside of the ring gear not the gear itself was was starting to scrape or dig into the cover alittle bit? wtf is that all about? so i hit the carrier bolts with a impact just for giggles. friggen rearends
