better drum shoes
Old Oct 6, 2010 | 12:34 PM
jungle's Avatar
jungle
New Member
Default better drum shoes
Is there any company that makes better brake pads/shoes for the rear for my 1500? Or am I stuck just getting the "best cermanics" that NAPA has? There are a bunch of options for the front, but I don't need those. Aside from having to cronically adjust the rear adjuster wheel....more rear brake would be nice. Especially since we have ABS in the back why not run a more aggressive pad?
I have noticed while towing (even w/ the brake controller) that the 1st axle to lock up is the fronts, then the trailer...so again more brake from the rear axle would be nice.
thanks in advance...
aaron...
http://junglemotorsports.blogspot.com
'95 1500, 318ci 180t-stat, HS 1.7rr, CAI, Adco rear sway, Bilstein HD shocks, Prodigy brake controller
'95 Neon ACR race car
Last edited by jungle; Oct 6, 2010 at 12:35 PM. Reason: not being able to have a real signature sucks
Old Oct 6, 2010 | 12:37 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Upgrade to the 1-ton rear wheel cylinders. I believe there is a DIY write up about this. It makes a world of difference.
Old Oct 6, 2010 | 01:53 PM
redheadhunter21's Avatar
redheadhunter21
I went with the bigger dodge wheel cylinders for the rear and it made quite a difference and the chevy 1-tons are a tad bit bigger and people have had good luck with them.
And I have not seen any aftermarket shoes but you might want to check out EBC they might have some
Old Oct 6, 2010 | 01:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The rear brakes are suppose to be adjusted every 6000 miles anyway. So basically, just do it at oil change time.
Old Oct 6, 2010 | 02:01 PM
UnregisteredUser's Avatar
UnregisteredUser
If you don't mind paying for what you're getting, check out these carbon Kevlar brake shoes at Circle Track Supply.
Old Oct 6, 2010 | 02:04 PM
zman17's Avatar
zman17
Lets not forget, the harder the shoe or pad, the quicker the drum or rotor will wear, if they are not upgraded also.
Old Oct 6, 2010 | 02:28 PM
UnregisteredUser
Yeah, but it's a relative thing. You're not going to chew through more than is necessary for the braking you're actually doing. With less dust and less gas generated by the high zoot frictions, you do less unnecessary damage. The problem I'd be worried more about is the greater ability to overheat the drums.
I haven't yet encountered any aftermarket better-than-OEM drums for 2nd gen Rams. Then again, I'm nowhere near needing any so haven't looked too hard. Has anyone found any?
Old Oct 6, 2010 | 02:53 PM
zman17's Avatar
zman17
I worded my post wrong, sorry. Upgrading rotors easy. The drums have to be top of line Raybestos(for example) or OEM. Not some Chinese junk steel from Advance or Autozone. They will warp/wear just like cheap rotors from the heat, although not as noticeable as a rotor does with pulsating.
Old Oct 7, 2010 | 01:08 PM
jungle's Avatar
jungle
New Member
Thanks for the replies, i will look into upgrading the wheel cylinders.
$180 for the kevlar ones seem a but nuts, considering a FLAPS is $30 for normal stuff, but....we might just consider that.
I JUST noticed that Wanger makes a "SevereDuty" line. Anybody got any info on those?
WAGNER Part # ANA462R
EBC doesn't make rear shoes... :S
