running a little hot at 230
Old Oct 9, 2010 | 05:14 PM
  #21
Joey Buentello's Avatar
Joey Buentello
most of these new threads are updates after I try something new. But ok whatever I'll keep stuff in the same thread.
Old Oct 9, 2010 | 05:20 PM
  #22
Joey Buentello
Also in other vehicles having timing thats off can result in having said vehicle run hot. But since our timing is controlled by our computer i figured I had retarded timing making my engine run hot (230). I also thought a programmer would take care of these problems.
Old Oct 9, 2010 | 11:38 PM
  #23
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by bggibbs
Jasonw Guess I needed to hear that also.
I guess we might be thinkin that a new thread produces activity and answers.
WILL MAINTAIN ALSO.
Gibbs
Anytime anyone posts in a thread, it gets moved to the top of the list on the main page (its the default sort method). Anyone worth discussing problems with will know that, and will read the thread.
Creating a separate thread actually does the opposite of "activity" and "answers". It annoys the people here that know the most, and annoying the knowledgeable guys is the last thing you want to do. No one wants to have to go through five threads (or however many) to find the original problem thread, and four updates. Its much easier to read (as well as keep the place organized) when its all in one thread.
The timing retardation caused by the "death flash" is not enough to cause heating issues with these trucks, otherwise we'd be hearing about that relationship all the time here. If the timing has been retarded enough to cause the truck to overheat, something worse than the "death flash" is wrong with your truck.
What all exactly did you replace in your engine rebuild?
Old Oct 10, 2010 | 12:24 AM
  #24
Joey Buentello
everything except for the rad which is what i'm doing tomorrow, I don't mean to bother you with my problems.
Old Oct 10, 2010 | 12:35 AM
  #25
jasonw's Avatar
jasonw
Site Moderator
No bother at all, thats what a forum is for, bouncing ideas around and solving problems.
Let us know what happens after you replace the radiator, if the cooling problem goes away or not.
Old Oct 10, 2010 | 03:23 AM
  #26
Joey Buentello
ten four
