Transmission Problems
Old Oct 17, 2010 | 10:27 AM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Oh sorry, yea, 97 is obd2. But the scanner might only pull engine codes.
Old Oct 17, 2010 | 10:50 AM
  #22
lennemann23's Avatar
lennemann23
Would an bad output speed sensor cause my problems?
Old Oct 17, 2010 | 11:23 AM
  #23
Possibly.
Old Oct 17, 2010 | 11:25 AM
  #24
95RAM360's Avatar
95RAM360
depends on the scanner...is it a snap-on scanner? they will pull tranny codes...the one from mac tools wont, and the autozone type scanners wont scan trannys as well...so it depends on the scanner.
Old Oct 17, 2010 | 11:34 AM
  #25
lblair04's Avatar
lblair04
Its very simple to do the gov pressure solenoid and transducer....drop the pan, cant remember if you have to take the filter off (might as well replace it), take a couple bolts out and disconnect electrical and swap the new parts in.
Old Oct 17, 2010 | 11:37 AM
  #26
zman17's Avatar
zman17
3rd to 4th, 4th to 3rd is usually the TC lock up and OD solenoids. And if the wires are frayed it can cause the rpm jumps.
Sorry about some confusion on my part, I got this thread mixed up with 2 other tranny threads!
Old Oct 17, 2010 | 11:39 AM
  #27
zman17's Avatar
zman17
Originally Posted by 95RAM360
maybe the overdrive selenoid is bad....which would require removal of the overdrive assembly, since its located inside the trans.
No it's not.
Old Oct 17, 2010 | 11:41 AM
  #28
Overdrive solenoid and such require the removal of the valve body, do they not? Sounds like a good time for the Sonnax Sure cure as well........
Or, I am full of ...... something.
Old Oct 17, 2010 | 11:56 AM
  #29
lennemann23
Hey Zman17. Where would I check for those wires to see if they are good? Also what is the chance that the output sensor is bad? And the OBD II reader I'm using is an Innova 3100 C. Thanks for everyone's help!
Old Oct 17, 2010 | 12:10 PM
  #30
zman17's Avatar
zman17
Yes, removal of valve body to make it easier, not the overdrive assembly as suggested by some one.
I gave you a link earlier in this thread that you apparently did not read, about the wires. Output speed sensor bad, will give symptoms youu have not mentioned(so I don't think it's bad). And that scanner you have will not work for the trans codes. Have you tried the key trick?
