how does this 360 short block sound?
Old Nov 28, 2010 | 02:19 PM
  #51
Seems not.... have a look here. get the numbers off the engine in question, and compare to the chart.
The 360's are pretty close to the bottom.
Old Nov 28, 2010 | 04:31 PM
  #52
matty675's Avatar
matty675
it looks like all magnums are
53020006. or not?
Old Nov 28, 2010 | 04:35 PM
  #53
Some of the non-magnums are as well. Get the numbers off the block, and compare them to the chart. And not all the magnums start with a 5 either...... 94-97 shows two possible numbers: 3418640 4027169.... so, see what ya got, see where it is on the chart.
Old Nov 28, 2010 | 08:05 PM
  #54
matty675's Avatar
matty675
arent 3418640 and 4027169 under the crank forging section?
Old Nov 28, 2010 | 08:07 PM
  #55
matty675's Avatar
matty675
this here confirms: http://www.enginebuildermag.com/Arti...0_engines.aspx
Old Nov 28, 2010 | 09:35 PM
  #56
Originally Posted by matty675
Yep. You are indeed correct. I was using the column header below, Ooops.
Old Nov 29, 2010 | 02:50 PM
  #57
matty675's Avatar
matty675
haha no prob man u pointed me in the right direction
Old Nov 29, 2010 | 03:28 PM
  #58
matty675's Avatar
matty675
any suggestions for transporting it in the bed of the truck?
Old Nov 29, 2010 | 03:52 PM
  #59
put it on a pallet, and TIE IT DOWN. I had a 440 block bounce around in the bed of my truck once..... that learned me good.
Old Nov 29, 2010 | 03:56 PM
  #60
J415's Avatar
J415
You can also sit it on a used tire then strap it down.
