8" lift kit question
Old Oct 31, 2010 | 09:00 PM
  #31
Gav1n8's Avatar
Gav1n8
yeah I'm with you on building a pack I just think your going a little far by saying there sketchy. I know a bunch of people on PS forum that love them. And I think its a much better solution than AAL and blocks for sure.
Plus zero rates fix the problem. Wouldn't say its a bandaid.
Lol dodge1500 I already said that...
Old Oct 31, 2010 | 10:55 PM
  #32
TheBigRedOne's Avatar
TheBigRedOne
Just because people love it doesn't mean its the right way to do it. No fault on you, I've been building suspension for over 10 years. I know what works, and what doesn't. Why do it halfass when you can do it the right way? 8 inches of lift is getting into the realm of ridiculous already, and using spacers/blocks/add a leaf to attain that height is just asking for a serious accident.
Just my .2
Old Oct 31, 2010 | 11:41 PM
  #33
dodge15004x45.9's Avatar
dodge15004x45.9
5" is pretty much point less you can't really use your truck with eazy like stock height.
Old Nov 1, 2010 | 11:17 AM
  #34
Originally Posted by TheBigRedOne
Buy a used G50 pack and beef it up with Blazer leafs. Cost me under $100 to do that.
I don't see how that is any different than an AAL. Taking a spring pack, and adding leaves to it?
What's a "G50"?
Old Nov 1, 2010 | 12:28 PM
  #35
TRTPLAYER's Avatar
TRTPLAYER
the skyjacker 7" kit comes with add a leafs and blocks so what difference is it if i use blocks and a add a leaf in the rear i dont see a problem with it and coil spacers why cant you put them on lift springs its not really different from when ou just stick a 2" soil spacer in for the leveling kit? but what should i do to make it a good kit that wont f???ing fall apart. i only paid 200 for everything so not like i got ripped off
Old Nov 1, 2010 | 01:21 PM
  #36
Gav1n8's Avatar
Gav1n8
Well what are you using this lift for? If your just gunna drive down the road and look cool and throw in a couple of dirt roads then aals are okay. If your going to use it to flex then your going to have to build a pack or do a shackle flip to get the *** up high enough.
coil springs and spacer that high up are meant to work like that. When that high, you need a taller spring and no spacer. 2500 coils are approximately 1.5-2 inches taller than 1500 coils. so get some 2500 coils that are 7 inch lift and that will net you 8.5-9 inches of lift on a 1500 for the front.
Its not going to F up as long as your not ramping it and junk... If your just wanting to dick around with buddys you will be fine.
Old Nov 1, 2010 | 03:19 PM
  #37
TRTPLAYER's Avatar
TRTPLAYER
like the truck is mainly a dialy drive from my house to shcool and take it off a could dirt roads here and there but no off roading stuff just high way use mostly
Old Nov 1, 2010 | 03:29 PM
  #38
Gav1n8's Avatar
Gav1n8
then put coils and spacer will be fine for the front. Use aals for the back or a skackle flip.
Old Nov 1, 2010 | 11:05 PM
  #39
TRTPLAYER's Avatar
TRTPLAYER
thanks everyone for all the help
Old Nov 2, 2010 | 02:50 PM
  #40
willstruck's Avatar
willstruck
So, what is a g50 pack, and blazer leaves? You guys got me interested in building a spring pack to lift my 2500. I don't want a big lift, just a few inches, but I want to get as much flex as I can out of it.
Is there a guide somewhere online for building leaf packs?
