Getting ALL the Air Out Of Coolant System
Old Nov 10, 2010 | 07:14 AM
  #31
dhvaughan's Avatar
dhvaughan
sounds good. just my opinion, but i never let rtv sit to setup. once torqued down, i go ahead and fill it and run it.
i replaced my antifreeze last week. i just pointed the nose uphill and let it idle up to full temp. it took 15 minutes or more. then topped off the rad and overflow tank and called it done. that took all the air out.
Old Nov 10, 2010 | 09:39 AM
  #32
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by dhvaughan
sometimes things just don't make sense.
back in the summer i was looking for rear axle seals for the daughter's 4runner. they were listed under "wheel seals" in brakes, as opposed to "axle seals".
are you going to rent a harmonic balance puller?
you'll need an impact wrench to remove/reinstall that big crank bolt.
tip - BEFORE installing the puller, reinstall the big crank bolt to protect those oh-so-precious threads in the end of the crank. you don't want to **** those up and don't ask how i know that. if you have trouble with the big bolt, apply some heat from a propane torch directly on the bolt.
before pulling the sprockets, rotate engine so the dots line up. then remove and reinstall. they're keyed so they only go one way. don't rotate engine with sprockets removed.
I really, really, REALLY want to ask how you know. I'm betting the story involves alcohol, a surfboard, two goats, and the local Fire Chief not being amused.
Old Nov 10, 2010 | 09:52 AM
  #33
zman17's Avatar
zman17
Retired Moderator - RIP
You forget the local police and the indecent exposure charges.
Old Nov 10, 2010 | 10:01 AM
  #34
Gary-L's Avatar
Gary-L
Veteran: Navy
That kind of goes hand in hand with the aforementioned surf board
Old Nov 10, 2010 | 07:03 PM
  #35
dhvaughan's Avatar
dhvaughan
i'm not like that anymore.
and don't believe anything those damn goats say, they'll lie every time.
Old Nov 10, 2010 | 07:37 PM
  #36
audiomechanic's Avatar
audiomechanic
HA! You say that, but I asked the sheep too and the stories match. What NOW mister?!
UPDATE: so I filled and bled as best I could tonight. I let her run for a good 20-30 minutes. The thermostat cycled a few times. So far, NO LEAKS! I still get the sloshing sound in my heater core, but hopefully parking it on an incline (Rhino ramps) will get the bubbles to the radiator as it cools.
So far so good...
Old Nov 10, 2010 | 08:19 PM
  #37
dhvaughan's Avatar
dhvaughan
fill the overflow tank to the max line with straight antifreeze. the air will work itself out within a few days.
those sheep are BAAAAAAADDDDD liars too. i was just helping it over the fence.
Old Nov 10, 2010 | 08:25 PM
  #38
audiomechanic
ROFLMAO!!!
Old Dec 20, 2010 | 02:31 PM
  #39
blackknight87's Avatar
blackknight87
Ok so i have the gurgle in my heater core in my 97 dakota. It has a new water pump, new thermostat and i just flushed the heater core and coolant system. Heater core is not leaking. So i suspect air in the coolant system. And it needs to be burped.
So i should park on an incline and take the radiator cap off? is this safe? what keeps coolant from coming shooting out when the engine heats up?
Old Dec 20, 2010 | 02:37 PM
  #40
Find a nice spot to get the passenger side front of the truck up nice and high. Driving up a hill at an angle supposedly works pretty good. DO NOT take the radiator cap off of a hot/pressurized cooling system, you WILL get a VERY rude surprise. I just drove to where I needed to be with the cap loose. (it wasn't very far.)
Or, drive the passenger front tire up onto a ramp.....
