DIY Fan Pully Holder (CHEAP!)
Old Nov 7, 2010 | 05:49 PM
audiomechanic's Avatar
audiomechanic
Default DIY Fan Pully Holder (CHEAP!)
Made this a while back and never spread the word about it. I needed a fan pulley holder so I could get the clutch fan off of my 5.9 Ram. I had some 1/4" bar laying around so I got creative. Works really well! Here's some pics:
Just cut and bend as such:
And, with the belt off, hook it into the alternator bracket opening and then insert the other end into one of the fan pulley holes. Then crank away!
Can't remember how much the bar stock cost, but it was really cheap. Can be found at Lowes/HD.
Old Nov 7, 2010 | 05:54 PM
charlie1935's Avatar
charlie1935
Very good!! Thanks for sharing.
Old Nov 7, 2010 | 06:16 PM
dhvaughan's Avatar
dhvaughan
damn clever !!!!!
Old Nov 7, 2010 | 06:22 PM
RM_Indy's Avatar
RM_Indy
That wont hold my efans
My 96 has bolt on water pump pulley so that wont work on early model years if still running oem water pump.
This is what I used to remove my viscous clutched fan.
Its fairly long so better leverage.
Rested the bar ontop of the fan/nut & notch under bolt on far side.
Held bar while unlocking fan.
Bit tricky but worked
Old Nov 7, 2010 | 06:47 PM
Gaius's Avatar
Gaius
Nice work. Neat time saver for sure.
Old Nov 7, 2010 | 06:58 PM
audiomechanic
Thanks y'all! I hope it helps someone.
Old Nov 7, 2010 | 07:17 PM
dodgeram07's Avatar
dodgeram07
wow that a great idea
better than mine
Old Nov 14, 2010 | 05:11 PM
lvolson's Avatar
lvolson
Good stuff to know since I am getting ready to do mine. A friend of mine suggested loosening the bolt while the belt is still on... to help. Assuming I am smart enough (I think I am) to not (manually) crank the engine while trying this, any reason not to try this first?
Old Nov 14, 2010 | 06:30 PM
Worth a shot. Worst that can happen is the pulley slips on the belt. No big deal.
