Heater core replacement instructions.
Old Nov 16, 2011 | 09:33 AM
  #31
Originally Posted by dog dodge
if i get a heatercore with rigid / non movable pipes will i have to disconnect ac lines ?
then if i do , do i have to recharge ac system if not using ac ? also if i open up ac lines can i just undo couplers in engine compartment by firewall by hand and not worry about the system being pressurized and blowing freon or whatever out ? as ive no idea because have never worked on ac system in truck
You don't want to just pull one of the couplers to drain the system. It is under rather good pressure, and you probably wouldn't like the results.
If you don't use it, no need to charge it.
You CAN install the rigid pipe heater core without discharging the a/c, its just a pita.
Old Nov 16, 2011 | 08:37 PM
  #32
dog dodge's Avatar
dog dodge
thanx heyyou . wondering how i discharge ac lines ? also are you 100% sure i dont have to recharge ac system , i ask because a local pro mechanic told me if they did job lines would have to be recharged . though maybe thats just him making money , or maybe its some type law .
Old Dec 20, 2012 | 11:27 AM
  #33
luiehipolito's Avatar
luiehipolito
Default 2000 Ram 1500 5.9
Can someone please share pics of when they replaced heater core through glivebox without touching or draining freon from A/C? I'd like to try doing that. I think I remember it being posted by member "working for ev4".....but pictures are no longer available.
I would greatly appreciate it,
Thanks,
Luie
Old Dec 20, 2012 | 11:59 AM
  #34
UnregisteredUser's Avatar
UnregisteredUser
That's not going to happen. It cannot be done. You have to move the instrument panel out of the way.
With the instrument panel out of the way, you can get just barely enough room to do the job without discharging the AC by pulling the HVAC box away from the firewall until the couplers hit on the engine compartment side. I cut the heater core pipes off and shoved them through to the engine side, myself.
Old Dec 20, 2012 | 09:05 PM
  #35
EndIsNear's Avatar
EndIsNear
You can do it through the glove box without removing the instrument cluster. Remove five screws from top of dash along windshield. Remove glove box. Remove knee guard underneath steering column. Remove small gear selector wire from holder. Two bolts on steering column can be removed and drop the steering column to seat. Remove kick panels on both sides. Loosen bolt on each side. Dash can now freely pivot back towards seat as well as be lifted up if needed. I have used a ratchet strap to pick up and hold dash using the Oh Sh*t handle on passenger side. Cut lines I engine bay. Small amount of coolant loss. Remove hoses and also cut excess from existing heater core pipes. Once hoses are off, use metal cutters, and reach through side or through glove box opening and cut both pipes close to the actual heater core itself. There are two tabs holding pipes down. Use a screw driver and remove them. Pull pipes through firewall. You can now pull up and remove core. Clean out with rag as best you can. With new core, pivot arms towards firewall holes and work it into slot at an angle. It takes time and you might have to force it just slightly. It will eventually fall into place. Replace tabs over pipes. Install now hose onto new pipes and tie into existing water lines. Replace dash same way as removed. Top coolant off and your done. I've done 4 pickups this way. With wish I had pics but I don't.
Old Dec 20, 2012 | 10:34 PM
  #36
UnregisteredUser
Originally Posted by EndIsNear
You can do it through the glove box without removing the instrument cluster. { ... } Dash can now freely pivot back towards seat as well as be lifted up if needed.
If you're rocking the instrument panel, then dammit you're not doing it through the glove box.
Old Dec 20, 2012 | 10:43 PM
  #37
EndIsNear's Avatar
EndIsNear
I misinterpreted what you meant lol my bad.
Old Nov 19, 2017 | 07:04 PM
  #38
StartingtolikeDodge's Avatar
StartingtolikeDodge
Default This really does work
So I know this is a few years late, but I had to respond. This really does work with a heater core that has the movable pipes. I just did it on a customer’s truck for kicks, and it took me 2 hours at a snails pace to change the heater core. I’m forever sold on this procedure.
Old Jan 15, 2026 | 10:48 AM
  #39
harleyjohn56's Avatar
harleyjohn56
Originally Posted by Baddnet
The instructions are good.. but I have done 2 of these...and can do it 2 hours.. remove screws from top of dash.. remove nuts/bolts holding steering column up.. loosen the 2 bolts on bottom of dash... the dash will now swing down.. remove heater core hoses from in/out tubes.. remove the 2 screws holding the tubes to the heater box ..they are located in side under the dash.. you will see them when you swing dash back.. use grinder.. cut tubes off old core.. pull tubes out through firewall.. pull core up out of heater box..it will pull straight up..
I used the heater core you can get at autozone.. the new core will have tubes that you can swivel.. swivel the tubes so they will go back through the firewall... slide the heater core back down in the heater box.... button it all back up..and your done.. I know some ppl.. dont agree with this method.. but it works and it is not such a pita.. just sayin
hi I was intrigued when you said the tubes on the auto zone core swivel. I looked up the duralast to fit my 98 Dak v6, but it looks like the tubes are fixed. Maybe the 98 has a different design and the replacement core does not have this feature. Thanks for your help.
Old Jan 15, 2026 | 06:13 PM
  #40
Moparite's Avatar
Moparite
There was a point all you could get was the non swivel. But now a days it's the opposite. Both can found if you look.
