water pump removal
Old Nov 20, 2010 | 04:05 PM
calumetbud's Avatar
calumetbud
Default water pump removal
can anyone tell me how to get the big nutt off the waterpump shaft..that holds the fan assmbly on..Thanks
Old Nov 20, 2010 | 04:26 PM
Either a spanner wrench. (the 'right' tool) Or, put a strap wrench on it. (some folks have just used a ratchet strap....)
In any event, secure the pulley to keep it from turning, put a big wrench on the nut, and smack the end with a hammer to get it to break loose.
Old Nov 20, 2010 | 04:44 PM
zje400ex's Avatar
zje400ex
I think I used the biggest cresent wrench I had and smacked it with a big hammer. It was a pita! It might take a few good swings with the BFH.
Old Nov 20, 2010 | 06:42 PM
lvolson's Avatar
lvolson
I borrowed the tool from Advance Auto Parts (loaner). I didn't have to change the pump after all so I never used it.
If you can afford to get one, you may want to read up on electric fans. Could save time and energy in the future.
Old Nov 20, 2010 | 06:46 PM
calumetbud's Avatar
calumetbud
i finally took it all off together where i can put it in a vice,i hage the a/c,alternator and the bracket off. you guys think of anything i need to replace while i have all that stuff off,be sides the thermostat. thats why i took everything off..thanks for the replies
Old Nov 20, 2010 | 06:51 PM
J415's Avatar
J415
If you wanna dig a little deeper, you can change the timing chain.
Old Nov 20, 2010 | 06:53 PM
This. Or, at the very least, the timing cover gasket. Since you disturbed a few of the bolts that hold it in place, there is a chance it is going to start leaking anyway.... and you will get to do all this again...... A good double roller timing set isn't too expensive..... Do it up. You are RIGHT there.
Old Nov 20, 2010 | 06:56 PM
calumetbud's Avatar
calumetbud
mmm,i will have to look that up and research it a little...thx...
Old Nov 20, 2010 | 06:59 PM
J415's Avatar
J415
I'll add to Hey you's post by saying if you don't do the timing chain and decide to change the timing cover gasket, also replace the front seal. Mine is leaking pretty bad.
Old Nov 21, 2010 | 07:31 AM
calumetbud's Avatar
calumetbud
Thanks for all the advice,things are getting interesting now...I am getting into thing i have never done before...I will have to do some reading how how toos and DIY's Thanks guys
