no injector pulse
Old Nov 21, 2010 | 03:46 PM
aim4squirrels's Avatar
aim4squirrels
I thought OBD 1 used 39psi and OBD 2 used a 49psi pump? I don't believe they are interchangeable.
Old Nov 21, 2010 | 10:24 PM
autolockguy13's Avatar
autolockguy13
truck is running after cleaning the ground and re wiring some things per the manual instead of how the guy who swapped it had them. thanks hey you for the pointer on the ground wire!
Old Nov 22, 2010 | 12:04 AM
Awesome!!! Enjoy your truck. Happy to be of service.
Old Nov 23, 2010 | 05:30 PM
vishnu's Avatar
vishnu
i would check your cam sensor inside your distributor. Its the plate below your rotor and check the gear also. good luck
Old Nov 23, 2010 | 05:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks for the info, but he already got it running.
Old Nov 23, 2010 | 05:49 PM
vishnu's Avatar
vishnu
I would check the cam sensor in the distributor. its the plate under the rotor which has alot to do with injector pulse. good luck
Old Nov 23, 2010 | 05:53 PM
Erm, re-runs?
