Coolant Leak in 5.2L
Old Nov 22, 2010 | 09:05 PM
Oakley Guy's Avatar
Oakley Guy
Default Coolant Leak in 5.2L
So today when I was taking off the battery charger (Left dome light on accident) I looked around the motor and noticed a coolant leak that was running down the motor. It wasn't a bad leak but its leaking alittle. I looked and it looks like its either coming from that pulley thats connected to the engine fan or is being leaked down on it. Its not leaking on the belt but around it. Is that the water pump?
Old Nov 22, 2010 | 09:10 PM
J415's Avatar
J415
Sound like you typical water pump failure. Check to see if it's coming out of the WP weep hole to verify.
Old Nov 22, 2010 | 09:13 PM
Oakley Guy's Avatar
Oakley Guy
Wheres the weep hole?
Old Nov 22, 2010 | 10:10 PM
Oakley Guy's Avatar
Oakley Guy
Im grabbing some photos because it seems like theres coolant leaking from the right side of the pump and running down. Im not so sure where the darn leak is coming from
Old Nov 22, 2010 | 10:20 PM
There are are a few opportunities in that area for leaks. Heater hose at the manifold, or, even the bypass hose under the A/C compressor bracket..... It fills the pocket on top of the timing cover, and dribbles out wherever the low point currently is.... there is also the upper radiator hose, and thermostat housing right there.... (and one or two sensors, but, those really aren't prone to leaking... check 'em anyway though.) Timing cover itself is another possible leak. (Not sure whose bright idea it was to have coolant pass thru the timing cover...... just another potential failure point.)
Old Nov 22, 2010 | 10:26 PM
Oakley Guy's Avatar
Oakley Guy
Old Nov 22, 2010 | 10:33 PM
I think you have more than one leak going on there....... Try cleaning the areas where coolant is quite obvious, take it for a drive, and have another look.
Old Nov 22, 2010 | 10:49 PM
Oakley Guy's Avatar
Oakley Guy
what do you think the possibilities of those areas are. Like where the leaks are coming from?
Old Nov 22, 2010 | 10:54 PM
Assuming the pics were taken from under the truck..... Water pump. Freeze plug behind the drivers side motor mount. Possibly the heater return tube up on top of the water pump as well, but, that one, you should be able to see from above.
Old Nov 22, 2010 | 11:12 PM
Oakley Guy's Avatar
Oakley Guy
Yeah, I wish I could find out the sources but I cant see anything when under the truck, and I dont know how to take apart stuff on the motor...
