97 dodge v6 died question
Old Dec 4, 2010 | 12:22 PM
gjwolf1's Avatar
gjwolf1
Default 97 dodge v6 died question
Hi all, I have a 97 w/ the v6. I had it going pretty high in 2nd gear heard rev limiter sputter and then it just died .. heard a pop
At first I was afraid the motor blew but it just sounded like you turned the key off
any ideas what I can check or what blew
thank you
G
Old Dec 4, 2010 | 12:23 PM
See if you get spark, and fuel pressure.
Old Dec 4, 2010 | 01:14 PM
gjwolf1's Avatar
gjwolf1
Default yep no spark
I had pushed it bit too high rpm then heard something pop... I jsut verified I have no spark
what do you think it could be? does something blow to protect the motor like rev limiter or something because I pushed it and kills spark like fuse?
Old Dec 4, 2010 | 02:00 PM
Check the crank sensor on the back of the block, passenger side. If that looks ok, I would run a compression check. You might have tossed some valve train components.
Old Dec 4, 2010 | 06:13 PM
gjwolf1's Avatar
gjwolf1
Default crank sensor pass side
you dont have any pics of it that you could point me to do you? on the pass side I do see something but more to the middle and looks teflon in w/ wires on top
from what I read lead me to believe the crank pos sensor was bolted in
thanks for your help
Old Dec 4, 2010 | 06:15 PM
You are going to have to crawl up in there to find it.... don't have any pics, sorry... You could grab the 01 service manual from the faq section here, it might have a diagram of some sort to show you where it is.
Old Dec 4, 2010 | 07:28 PM
gjwolf1's Avatar
gjwolf1
if I destroyed the valves wouldn't it would still be getting spark wouldnt it?
Old Dec 4, 2010 | 08:17 PM
dodgeman52's Avatar
dodgeman52
maybe it jumped time?
Old Dec 5, 2010 | 12:30 AM
How does it sound when it is cranking? Normal? Or does it 'freewheel'..... lousy term.. but, not sure how to describe what I am getting at..... does it sound like you are getting compression on all cylinders?
Old Dec 5, 2010 | 03:28 PM
gjwolf1's Avatar
gjwolf1
Yes, it sounds normal- it doesnt freewheel...
question on the crankshaft position sensor.. does it not bolt in like I see many others? If I post a pic would you tell me if that is it or Im looking at the wrong thing
What im looking at is on pass side far back on block but adjacent to distributor, looks almost like teflon in but i think it screws in w/ wire cap or some connector on top- is that it?
I've mirrored the area and dont see anything else unless I need to be looking from the ground up the back of block
Please let me know and thanks again for the help
G
