408 stroker build
Old Jan 25, 2011 | 03:13 PM
  #241
Originally Posted by matty675
AHHHH, hence the edit while you were typing that
if you were in my situation would you put down $500 for KB .040s and a +.010 bore?
Depends on why you are doing it. I seem to remember something about the pattern being 'off', or some such? Don't recall why a fresh hone job wouldn't clean it up, as the engine hasn't been ran at all, cylinders should still be in good shape.....
Old Jan 25, 2011 | 03:17 PM
  #242
matty675's Avatar
matty675
corrosion was not completely removed by the flex hone, if you run your finger over it you can still feel it
Old Jan 25, 2011 | 03:24 PM
  #243
How close are you to your tolerances? Can you clean 'em up a little better?
Old Jan 25, 2011 | 03:28 PM
  #244
matty675's Avatar
matty675
we tried the best we could to get em nice and clean but those patches wouldn't polish out. i know there not within spec because i can feel the raised patches.
Old Jan 25, 2011 | 03:44 PM
  #245
I would run a bore gauge up 'em, and see what the gauge says. The different texture can fool a finger.
You guys use a ball hone? or flat stones to try and clean 'em up?
That said.... I am not right there to have a look.... so, best I can do is guess. I think I would still try and clean them up with a hone first though.....
Old Jan 25, 2011 | 03:51 PM
  #246
matty675's Avatar
matty675
ball hone.
guess i could get the original builder to see what he thinks.
Old Jan 25, 2011 | 03:55 PM
  #247
ball hone.
Running a flat stone on it may not be a bad plan.....
Talking to the machine shop guy sounds like a good idea.
Old Jan 25, 2011 | 04:04 PM
  #248
matty675's Avatar
matty675
yea i feel stupid because i keep calling him and trying to get an over the phone diagnosis and estimate. ive also told him im going to bring it by several times...oops
i know the best thing to do is to get him to ACTUALLY look at it. i know it will run good as is, BUT i like i said, i want it to be PERFECT
Old Jan 25, 2011 | 04:14 PM
  #249
Toss it into whatever you have for transportation, and cruise it down to him to have a look. He might even be willing to whip out with the bore gauge, and have a look.
Old Jan 25, 2011 | 05:20 PM
  #250
matty675's Avatar
matty675
ok ill do it friday
needless to say the lever action spring compressor i bought at advance was sh*t for those springs. any reccomendations if i need to remove them for some reason?
