engine lugging badly/ vibrating in lower rpms. help!!
Old Jun 21, 2011 | 11:53 PM
  #61
Cool. Yeah, having the fuel system in good shape for that is definitely a good plan.
Old Jul 19, 2011 | 02:53 PM
  #62
matty675's Avatar
matty675
ordered a delphi fuel pump from rockauto for $200, cant beat the price!
i was going to remove the bed and go that route... is the haynes procedure really necessary (releiving fuel pressure etc.) or can i just remove the bed and pull the pump, no questions asked?
Old Jul 19, 2011 | 03:04 PM
  #63
Depends on how long it sits after last running, and how adventurous you are.
If you have the valve on top of the fuel rail, you can relieve pressure there.... or, you you can take your chances when you pull the line off the current unit. (make sure you take the gas cap off first though.)
I really don't know which is easier.... drop the tank, or lift the bed..... Suppose it depends on how much gas is in the tank.
Old Jul 19, 2011 | 11:41 PM
  #64
matty675's Avatar
matty675
my thoughts are, 6 bolts vs dropping a tank with 13 gallons of fuel in it
Old Jul 21, 2011 | 02:22 PM
  #65
matty675's Avatar
matty675
are the bed bolts really metric?! 15mm?
Old Jul 21, 2011 | 03:57 PM
  #66
Wouldn't surprise me...... seems american automakers can't make up their minds if they want to do standard, or metric, so, they use both.... fun huh?
Old Jul 21, 2011 | 04:37 PM
  #67
matty675's Avatar
matty675
are those end bolts a pain in the asssssss or what?! any special tricks besides ratcheting one click at a time????
Old Jul 21, 2011 | 05:32 PM
  #68
matty675's Avatar
matty675
how do you remove the fuel line from the pump?
Old Jul 21, 2011 | 06:15 PM
  #69
matty675's Avatar
matty675
got the fuel line off, now my problem is i cant get the plastic lock ring to move PERIOD! im using a vice grip chain!
Old Jul 21, 2011 | 06:46 PM
  #70
matty675's Avatar
matty675
ok, got the new pump in, but it seems to be leaking just a hair where the line hooks up to the pump... what to do?
i replaced the plastic lock tab and that didnt help... is it the fuel line itself?
dealer only part?
anyone tackled this? it seems like it disconnects under the driver door, but i cant figure out how to disconnect it.
this is truly annoying, i try to fix one thing, and another breaks...wtf chrysler
