vibration/grinding
Old Dec 8, 2010 | 01:42 PM
Jamie71's Avatar
Jamie71
Default vibration/grinding
Hey there, i am having a problem. When I am driving I feel a vibration/grinding in the front end and my 4wd light flashes on sometimes. I changed the front differential gear oil out and it still persist. Does anyone know where or what the noise is coming from? Please help, thanks.
Old Dec 8, 2010 | 01:47 PM
Central axle disconnect. Check the vacuum lines going to the little box on the passenger side of the front axle. Should have vacuum at the outboard port when in 2wd.
Old Dec 8, 2010 | 01:54 PM
Jamie71's Avatar
Jamie71
Are you referring to the little box housing for the left axle?
Old Dec 8, 2010 | 01:55 PM
Jamie71's Avatar
Jamie71
Sorry, right axle i meant.
Old Dec 8, 2010 | 02:05 PM
Jamie71's Avatar
Jamie71
oh by the way i have a 2001 dodge ram 1500 4wd 5.2 engine, just need to figure out what is going on and why is the 4wd light flashing on and off, thanks
Old Dec 8, 2010 | 02:08 PM
Yep. little box feller on passenger side axle tube. Might wanna take it off, and inspect everything, and verify it does what it is supposed to, sounds for all the world like it is not....
While you have it up in the air, check your wheel bearings as well. Having one abandon you while you are using it isn't much fun.....
Old Dec 8, 2010 | 02:14 PM
Jamie71's Avatar
Jamie71
I replaced the left wheel bearing nub a couple of months ago and it was shot, didnt change the right one cause it was still good and they aint cheap
Old Dec 8, 2010 | 02:40 PM
I would have a look at both anyway.
Old Dec 8, 2010 | 02:49 PM
Jamie71's Avatar
Jamie71
The other day i took both wheels off and inspected the wheel bearing hubs and they seem fine, no play and spun freely with no problems. So i guess i will check the vacuum lines and CAD and hopefully that will be where the problem is, hopefully
Old Dec 8, 2010 | 02:56 PM
Pretty good bet if the wheel bearings are ok.
