4wd not staying engaged
Old Dec 14, 2010 | 10:40 AM
Ram_King's Avatar
Ram_King
Default 4wd not staying engaged
last night i was driving in 4wd and it would just kick out when it felt like it. any ideas? it a 1997 1500 sport.
Old Dec 14, 2010 | 10:53 AM
Vacuum leak?
Old Dec 14, 2010 | 11:20 AM
chrscott's Avatar
chrscott
Did the t-case shift lever move, or did 4x4 just dis-engage?
If the t-case shift lever moved, I would guess mis-adjusted linkage (had an old Dakota that would do the same thing).
If the 4x4 light just went out (and you lost 4x4), but the t-case shift lever did not move (stayed at 4-Hi), then I am with HeyYou and would guess vacuum leak, or bad diaphragm.
Old Dec 14, 2010 | 07:01 PM
Ram_King's Avatar
Ram_King
How do i adjust it?
Old Dec 14, 2010 | 07:27 PM
matty675's Avatar
matty675
most common problem with these is bad vac.
ensure that the red line at the cad has around 17" in 2wd and then when in 4wd the black line should have 17". if no vac is found, trace the lines all the way up to the passenger side of the manifold, somewhere in there you will likely find your problem, if not a new t-case switch is in order
Not exactly sure just what the problem is here. Does the little lite go out? Or, does the shifter pop out of 4x4??
Old Dec 15, 2010 | 09:09 AM
Ram_King's Avatar
Ram_King
the shifter kicks out and the light goes out.
Old Dec 15, 2010 | 11:24 AM
Ah, you need to adjust the linkage then, and see it that solves the problem, If it doesn't, you are going to need to dig a bit deeper. (possibly broken snap ring on rear output shaft.)
Not sure if there is a DIY for the adjustment in the faq section, take a look though.
Old Dec 15, 2010 | 11:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The range fork or something else inside the TC is bad, you may have simply broken the snap ring, in which case one of these might fix your problem. http://www.drivetrain.com/parts_cata...ase_saver.html
I wouldn't wait too long to try it, if it is the problem, other bad things are going to happen to the case.
