Where are the head light relays
Old Dec 17, 2010 | 05:29 AM
Lone136's Avatar
Lone136
Thats the part I don't understand. There is only two head lights on the truck.
Old Dec 17, 2010 | 10:10 AM
Hhhhmmmm.......
If it were me...... I would use the current power wires AT the headlights to simply trip a relay, which would feed power to a second set of relays, that were switched in the cab, to route power to either the stock lights, or, the plow lights. Headlight switches in these guys weren't the best to begin with, so, having it just control a relay would hopefully prevent other problems.....
Old Dec 17, 2010 | 10:53 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
These are the 'quad' headlight heyyou is speaking of:
Yes, I took that from my special collection.
The quad model housings, only available on 99-2002 Sports, use two bulbs, one for high beam and one for low.
On the new Ram they are called "quad burner" head lamps.
Old Dec 17, 2010 | 09:44 PM
pro tech's Avatar
pro tech
Here is a link to what I'm going to wire amd what I need help with
http://library.fisherplows.com/ddcom...017_031599.pdf
You will also see a pur wire and BRN, Gray wire. I need to find out where they go as well. I'm not the greatest at AUTO wiring, but can wire a home with my eyes closed
That's weird.....the PDF looks like the wiring diagram for the later Sport models which have 4 bulbs, 2 low and 2 high beam. and I would assume a relay for each.
Could you have gotten the wrong harness for your truck, or do you have the 4 bulb headlight set-up?
My '96 (non-Sport) with the single bulb headlights has only one relay and the Meyer plow set-up was easy plug n play, with the correct harness....LOL.
Old Dec 18, 2010 | 08:04 AM
Lone136's Avatar
Lone136
I know I will be getting a hard time for this one. but I do have a chevy as well that has a meyer plow on it and Yes it was plug and play.
I need to reword this, There are 4 bulbs, 2 head light and 2 park and I would think turn signal bulbs. I also sent Fisher a Email, but they haven't responed.
Sorry it has takem me a day or two to get back to this, but we had a compressor go bad at the store to the walkin cooler, but able to get it up and running late last night.
I guess I will go back down to fisher today and ask them in person. I'm just sick of all of this now. Should have gotten a Meyer plow for my Dodge as well.
