4 wheel drive wont work
Old Dec 22, 2010 | 05:45 PM
Mike2500's Avatar
Mike2500
Default 4 wheel drive wont work
on my 01 dodge 2500 my 4wheel drive wont engage.i looked underneath the passenger side and there was a black and red vacuum line that was broke. i fixed them and now it still wont engage. i was told about fixing the 4wd switch but i dont know anything about the 4wd setup.
Also how do i remove the front oxygen sensor off my truck. i have tried everything to it,I have heated it with a torch,used everytool available,all it has done is stripped it out on like 2 sides.I was told to use some type of lubricant on it it is in a orange can, I have been fighting with this for like the last three months and its screwing my truck up.
mike
Old Dec 22, 2010 | 06:18 PM
If you are going to replace it...... Just use a pipe wrench to grab a hold of it, and then whack the end of the wrench with a hammer (big one....) until it breaks loose. Chemicals like PB Blaster, Freeze Off, Knock 'r loose, etc, certainly won't hurt. Mine was a real bear to get out too. The two foot pipe wrench, and the 3 pound hammer finally convinced it though.
Old Dec 22, 2010 | 07:16 PM
Mike2500's Avatar
Mike2500
ive used pb blaster and the pipe wrench method ive also used wrenches,sockets even vice grips but to no avail she aint budgin and where dodge put it its really tight.
Old Dec 22, 2010 | 07:29 PM
dhvaughan's Avatar
dhvaughan
you're going to have to get mean with it.
get a can of PB-Blaster penetration oil and soak the threads several times per day for a couple of days. get a good pair of vice grips that can really clamp down on it and not strip or round it any further. put a piece of pipe on the end of the vise grips for more leverage. use a torch to heat the sob up as hot as you can get it. a plumber's propane torch is good enough, but it'll take a few minutes to get it really hot - don't get burned.
now lay into it with the pipe. make sure you're turning it the right way
Old Dec 22, 2010 | 07:31 PM
dhvaughan's Avatar
dhvaughan
mike
read this http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Dec 28, 2010 | 03:50 PM
edjohnson's Avatar
edjohnson
to remove the o2 sensor, i ran my truck for 15 minutes got the pipe real hot, and it came out
Old Jan 7, 2011 | 08:02 PM
Mike2500's Avatar
Mike2500
i fixed the 4wd problem, Thanks for all the help on that.
On my other dodge my brother decided that cutting the o2 sensor completely off was the right idea,well it wasnt he cut it completely flush so i cant use anything to get it off. Can i just cut a new hole below the old o2 and weld in a new nut for it because ithere is no threads showing for the old o2 and its killin my truck.
mike
Old Jan 7, 2011 | 08:24 PM
Ooops......
What did he cut it off with? If you have a wizz wheel, just cut out the current bung, and weld in a new one......
Old Jan 7, 2011 | 11:28 PM
Mike2500's Avatar
Mike2500
he cut it off with a sawzall
Old Jan 8, 2011 | 01:29 AM
LOLOLOL. One of my favorite tools for exhaust work.
Can you bust up whats left? And clear the hole that way? (fishing it out of the cat might be fun though......)
