no trans check valve
Old Jan 2, 2011 | 05:13 PM
dipsherry's Avatar
dipsherry
Default no trans check valve
ok i went to go do the check valve delete and my truck doesnt seem to have one...or maybe i am looking for the wrong thing i used the pics in the faq as a reference...
here is my lines
Old Jan 2, 2011 | 05:19 PM
gremlin2033's Avatar
gremlin2033
from me looking at your picture u dnt do u have an external cooler
Old Jan 2, 2011 | 05:20 PM
Wow. You are correct, I do not see one in there.... No idea if they put it elsewhere on the earlier trucks, or, if it is indeed something that showed up later....
Should have been on the line that runs right above the lower radiator hose, and, it isn't there.....
Old Jan 2, 2011 | 05:24 PM
gremlin2033
i have a 94 and mine had one so idk
Old Jan 2, 2011 | 05:25 PM
dipsherry's Avatar
dipsherry
i know i looked and didnt see anything that looked even close to a check valve. mine being a 94 maybe they didnt have on who knows
Old Jan 2, 2011 | 05:40 PM
dodgeram07's Avatar
dodgeram07
maybe,,, my 95 has one
Old Jan 2, 2011 | 05:47 PM
Twisted Metal's Avatar
Twisted Metal
My 2 previous Rams (94 and 99) both had it. Also my current 01. Possibly an external trans cooler at one time? Or the line(s) have been replaced?
Old Jan 2, 2011 | 05:48 PM
TheBigRedOne's Avatar
TheBigRedOne
That's looking like it has an external cooler.
Old Jan 2, 2011 | 07:43 PM
dipsherry's Avatar
dipsherry
ok so i just went and took a vid and then i dug thru my old emails and found my build sheet it said something like this...NHBP Auxiliary Transmission Oil Cooler so i guess i answered my own questions...also i got my title and checked it says my truck is a 2500 but i have 5 lug wheels is this possible
oh and here is the vid i took the time to take it figured a few of you could suffer through it to hear my lovley voice HAHA
http://www.youtube.com/watch?v=NxcnwWs7UUY
Old Jan 2, 2011 | 08:00 PM
Gerehead8's Avatar
Gerehead8
Good to hear you got your title but it sounds like the wrong one. Does your door jam Vin and Dash Vin match the title? What is the GVWR of your truck according to the door jam sticker? 1500's should be 6400 and LD 2500 about 7400. The LD 2500 should have an 8-lug Chrysler 9.25 HD but since yours is a 2wd Dodge may have been able to get the capacity with the lighter duty 5-lug axle.
