thinking of seafoamin my truck
what are your guys' opinions on seafoam? ive heard good and bad things and wanted to know any gains or losses.
also, if you have used it, how much did you put in and where?
diff worth the money, 1/2 bottle in the brake vac hose half in the crank case and a whole bottle in the gas... drive your truck around for about 20-30 mins then add the seafoam to the engine and let it sit for about 15-20 min. then start it and let the smoke roll rev the engine until smoke stops... drive it 100 miles then change the oil
never add seafoam to the oil. never add any solvents to the oil.
Just use a whole bottle in the vac line. But do it 1/2 on drivers side, then 1/2 on the passenger side.
Seafoam in the gas is OK. but if you can find a GIANT in line fuel filter, put seafoam driectly in that and then connect to your fuel rail. it will REALLY clean out injectors.
That get rebuilt how often?
Trending Topics
Google it...
If I wanted to flush sludge, I would just run 1 synthetic oil change per month for 3 months to get a handle on sludge. Best way to "clean" an engine of a car that you bought from someone is to change the oil more frequently for the first year. Fresh oil is the best cleaner.
I think the consensus about seafoam in the oil is this:
Do not do it to a truck that you just bought and have no idea on the history.
