Removing the shifter knob on a 98 1500 automatic
How would you go about removing the shifter **** on my 1998 1500 automatic shifter? I was thinking of replacing it with something a bit nicer.
You have to take some vice grips and crunch it and then pull it off. It doesn't unscrew like you think it would.
edit- nevermind I see you have a 98 with the O/D on/off button on the shifter, hopefully someone will chime in that has messed with a 98 or newer column shifter.
Is this your shifter ****?
I had to pull mine apart to get the o/d button cleaned out and actually cracked the **** a little. From what I remember its pressed on there (may have a little adhesive?) so just work it gently (which I didn't) and pull it out straight to avoid cracking. The wiring is wound up in there and there is enough to pull it clear of the lever.
Found this thread will searching for an answer to this same issue some years later - unfortunately. Figured I would post what I discovered over several searches. The end with the OD button was not made to replace. The complete automatic shift handle assembly can be purchased (Mopar Replacement 4690522AB); however, once you get the steering column shroud off you find the handle has a pressed in pin that holds it in place. Ordered a door hinge removal tool (Eastwood Door Hinge Pin Puller Removal Tool Kit). The new handle assembly comes with everything needed. Easy job once you get the part and the pin removal tool.
Last edited by 98DodgeRamFan; Apr 20, 2020 at 02:12 PM. Reason: Updated details of what was found.
Trending Topics
I seriously doubt the part is still available. Possibly in the NS1 network, if Chrysler still uses thta.
