do i have everything?
Old Jan 4, 2011 | 05:45 PM
talon6's Avatar
talon6
Default do i have everything?
well, i think i am about ready for the build finally. here's what i have setting in the garage just waiting. please let me know if i am forgetting something.
eq 2.02 iron heads
sealed power full gasket set
mopar r/t +10 cam
mopar double roller chain
mopar chain tensioner
antiseize
cam lube
antifreeze
oil&filter
180*stat
head bolts
remflex header gaskets
stage8 locking header bolts
water pump&by pass tube
mopar .600 springs and retainers
threadlock
engine paint
plugs, cap and button
engine degreaser
red rtv sealant
i think thats it. let me know.
Old Jan 4, 2011 | 06:00 PM
Gonna need a wideband O2 sensor, and a custom tune. (the wideband is so you can clue your tune writer in to what you need.)
And of course you are missing something. You will need to make at least three trips to the parts store. Isn't that written in stone somewhere?
Old Jan 4, 2011 | 06:03 PM
talon6's Avatar
talon6
wideband is already installed, and hemifever has already got me a tune for my sct to get started with.already loaded on my tuner.
and yeh, no matter what, you think you have everything and boom. its off to the parts store. lol
Old Jan 4, 2011 | 06:12 PM
Where in ohio? Would love to see it when you got it on the road.
Old Jan 4, 2011 | 06:14 PM
talon6's Avatar
talon6
se ohio. close to zanesville.
Old Jan 4, 2011 | 06:18 PM
Ah, thats a cruise from here. 3 or 4 hours maybe?? Although, I DO have friends in columbus.......
Old Jan 4, 2011 | 08:07 PM
talon6's Avatar
talon6
columbus is about 50 min away. so is wv from me.
Old Jan 4, 2011 | 08:09 PM
yeah, I looked up zanesville on the map.
We should look at maybe getting the members in the vicinity together at some point this summer.
Old Jan 4, 2011 | 08:19 PM
dhvaughan's Avatar
dhvaughan
torque wrench, balance puller, 3/8 fuel line disconnect, big wrench for fan nut. strap wrench or tool or hook to hold wp pulley.
timing cover front seal
you going to pull the motor? bearings? rings?
oil pump, rear main, oil pan gasket
freeze plugs
plug wires
valve cover gaskets.
Old Jan 4, 2011 | 08:28 PM
talon6's Avatar
talon6
Originally Posted by dhvaughan
torque wrench, balance puller, torque wrench, 3/8 fuel line disconnect, big wrench for fan nut. strap wrench or tool or hook to hold wp pulley.
freeze plugs
plug wires
yes i am pulling the motor. i am not doing anything to the bottom end.i only have 65k on motor and think it will hold up for awhile.
my plug wires only have about 5k on them. gonna reuse them.
torque wrench-have it
balance puller-rent it from advanced
fuel line tool-have a couple
strap wrench-got a couple different sizes
fan nut-already gone, have e-fan
degree wheel kit-bought a new one from comp cams
