Middle of plenum build and I broke it.
If that's the only coolant temp sensor you have, then it is also the one that gives the PCM coolant temp readings, which it uses for several purposes. If you have 2 temps sensors, then that is probably the dash gauge one.
I did the same thing in my install. It was 15 dollars at autozone for a drualast one. No problems, however, it looks like my coolant temp is pretty low (but then again, i changed the thermostat to a 180*).
Or you can get a better quality one from rockauto.com. Autozone, 14.99. Easy fix.
Hughesengines.com sells a MSD brand one for 15 bucks as well.
No biggie, a handfull of us who did our plenums broke ours. And almost 90% of us replaced it when doing the plenum anyway. I broke mine when i was using some channel locks to open my hose clamp. it was lmost like i didn't see the darn thing.
