just a transmission related question
Old 01-08-2011, 08:09 AM
thompson1986's Avatar
thompson1986
thompson1986 is offline
Default just a transmission related question
a friend of mine warned me about my trans going out and said one of the signs would be that if i shifted into reverse i would hear a whining noise and a delay in power and difficulty shifting between 2nd and 3rd gear.
i have the delay going into reverse, however i assumed it was because of my bald completely worn out bias ply swampers developing flat spots other wise i have no noticed issues shifting gears or anythign else transmission related aside from a small fluid leak by the radiator, but thats just a hose in need of some minor adjusting
and i read on here a few weeks ago about some check valve, but i cant remember what i was supposed to do with it, replace it remove it blow it up etc etc
Old 01-08-2011, 11:20 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,214 Likes on 2,965 Posts
A slight delay going into gear when the truck has been sitting for a bit is normal. When the trans is in park, the pump does NOT send fluid to the torque converter, so, if it has sat for a while, and emptied out...... when you put the truck in gear, first thing that needs to happen before the truck will move is, it needs to fill back up. (and this is also why checking your fluid in park gives you an inaccurate reading.) If it does it ALL the time, you might have something to worry about.
Try putting the truck in neutral for a bit before trying to move it when it has been sitting for a while. See if that helps.
Check valve is in the trans cooler line running TO the radiator, right up near the radiator. Just have a look at the steel lines there, if it is still in there, you will see it.
You want to remove that valve. It tends to clog up, and restrict, or, stop, flow thru the cooler. Trans overheats...... and smokes itself. Bad scene. Very expensive.
Old 01-08-2011, 07:13 PM
thompson1986
im glad you reply mr HEYYOU otherwise i would have at least two posts with no replies.
Old 01-08-2011, 10:15 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
Check out the faq's section allot of info in there on these trucks and the known issues, and fixes for most of them.
Dave
Old 01-11-2011, 08:15 AM
thompson1986
now every once and a while the thing dies when shifting from reverse to drive and i am at a complete stop when shifting
Old 01-11-2011, 10:00 AM
HeyYou is offline
Did you change anything?
Old 01-11-2011, 04:40 PM
thompson1986
no i have not had time to change anything.
Old 01-11-2011, 05:01 PM
HeyYou is offline
Does it do it most when cold? Warmed up? Not quite there? What does the engine idle at warm/cold? (normally)
Old 01-12-2011, 08:56 AM
thompson1986
does it only when cold, the engine normally idles at about 800 when cold for a few minutes then when its warmed up a bit drops to about 500 RPM i was a little low on trans fluid, put about a quart and a half in
Old 01-12-2011, 09:35 AM
HeyYou is offline
Sounds like an O2 sensor on its way out.
Quick Reply: just a transmission related question
