a518 overdrive unit install
Old Jan 8, 2011 | 12:42 PM
northern terrain's Avatar
northern terrain
Default a518 overdrive unit install
Hello eveyone, I have a 2000 Dodge Ram 1500. I am triing to install a rebuilt overdrive unit on the transmission. I am able to get the splines lined up, however the unit stops about 1 inch short of the mating surfaces. any help would be greatly appreciated.
Old Jan 8, 2011 | 12:48 PM
J415's Avatar
J415
Did you use the appropriate aligning tool to make sure all the splines line up? click on the link to see the specialty tools needed. I think that's the problem.
http://www.transmissionpartsusa.com/...-000jt1318.htm
Old Jan 9, 2011 | 10:26 AM
northern terrain
Default overdrive alignment
Thank you for your reply, I must admit this installation has been challenging. I was hoping you might explain, what needs to be aligned on the OD unit that is not allowing me to complete the installation. I have no problem spending a $150 to get this truck back on the road, I just do not understand what I am missing where alignment is concerned.
Old Jan 9, 2011 | 04:52 PM
xjarhead69's Avatar
xjarhead69
Read this http://joelsgarage.blogspot.com/2008...ssembling.html.
About half way down will explain what J415 is talking about.
Dave
Old Jan 9, 2011 | 06:32 PM
J415's Avatar
J415
Dave
Thanks Jarhead. That's what you need to do. I had the same problem when I installed my OD unit until I figured it out. By the way, that blog along with the ATSG manual helped me out tremendously!!!
Old Jan 12, 2011 | 10:55 AM
northern terrain
Thank you all for your help. I bought a rebuilt overdrive unit, would I need this alignment tool with an assembled unit?
Old Jan 12, 2011 | 10:58 AM
northern terrain
Dave
I am tiing to install a rebuilt overdrive unit. Will I need the alignment tool to install a unit that was rebuilt by a certified mechanic?
Old Jan 12, 2011 | 12:12 PM
J415's Avatar
J415
It doesn't matter who built it before you. If your gonna disassemble and reassemble your OD unit, you need that alignment tool in order to align all the splines together so that the OD unit sets well to the main barrel of the tranny. Also, If you decide not to measure for you spacer, put the old spacers in. Either or.
Old Jan 12, 2011 | 03:34 PM
northern terrain
Thank you for your help. I will order the the alignment tool. Is there any special techniques, or should I order a service manual as well?
Old Jan 12, 2011 | 03:37 PM
J415's Avatar
J415
If you could hold off on ordering those parts until later on tonight, I can direct you to a free manual.
Check out the is link. It's very helpful.
look at the video in post # 6
https://dodgeforum.com/forum/2nd-gen...smissions.html
also, check this out:
https://dodgeforum.com/forum/2nd-gen...nsmission.html
