Transmission issues, same as last year
Old Jan 10, 2011 | 09:50 PM
cosmorphis's Avatar
cosmorphis
Default Transmission issues, same as last year
Hello everyone!
Last year I was having some transmission issues with my 2001. I posted in Monte's Transmission Corner, and he recommend three things. 1) Adjust the throttle valve cable 2) Replace the throttle position sensor 3) replace the governor pressure sensor solenoid. I did 1 and 2 with no luck. Only after did I replace the governor pressure solenoid (and the governor pressure sensor just to be safe), did it work fine again.
Well, that was in April of 2010. Recently, I was trying to adjust the throttle valve cable, to get earlier shifts. It was going fine, until the other day I went to pass a car, and now the symptoms have returned all over again. It acts like it gets stuck in gear, and won't shift up when it needs to. I put the throttle valve cable back in to the original position, but it still is acting bad. Did I screw up the governor pressure solenoid??
I'll drop the pan and do it all over again, but I just wanted to get a second opinion first. Is it that easy to break the solenoid?
Thank you!!!
Old Jan 10, 2011 | 09:55 PM
matty675's Avatar
matty675
did you use a MOPAR solenoid and sensor?
Old Jan 10, 2011 | 10:40 PM
cosmorphis's Avatar
cosmorphis
I don't think so, but I don't know for sure. I ordered them both from transmissionpartsusa dot com. Here is the solenoid and the sensor.
Old Jan 10, 2011 | 10:47 PM
Its possible that the pressure control solenoid just gets dirty, and then doesn't function quite as well as it should. The GM system, with a self-cleaning pressure control solenoid, is actually a superior system. Wittrans has conversion kits for the dodge transmissions, for just such an occasion.
Old Jan 10, 2011 | 11:05 PM
cosmorphis's Avatar
cosmorphis
Awesome! Think you could post a link or the part number? I am at their website, but I don't see it. I found S22167A Valve Body Kit, A518/A618 Gas/Diesel 1999-03 (Superior). Is that it?
Old Jan 11, 2011 | 10:12 AM
Here Ya Go. make sure that's the right part for your year.
