Brake and ABS light came on!
Old 01-12-2011, 12:55 AM
DodgeTheFather Ramthe Daughter's Avatar
DodgeTheFather Ramthe Daughter is offline
which fuse did u replace cus my truck has the same problem, my breaks are super sensitive when the light is on and the lock up very easy
Old 01-12-2011, 10:46 AM
1995crow's Avatar
1995crow
1995crow is offline
Yeah mine dose it to but not the brake light its the abs and air bag light sometimes when I start the truck and I can't roll down my windows or lock my doors anyone know why it dose it?
Old 01-12-2011, 01:26 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
Originally Posted by chromed95
+1 on the fuse, that's most likely your problem Ram King. I had those same lights come on after i hooked up to a trailer that had been wired wrong and it blew me fuse for those lights. Its the same fuse for both. Check it, and replace if bad.
Exact same thing happened to me. Hooked up to a jetski trailer that wasn't wired right, blew the fuse out.
Old 01-12-2011, 03:13 PM
chromed95's Avatar
chromed95
chromed95 is offline
I can't remember which one i replaced honestly, and I just went and looked. it was a few years ago when this happened to me. But if you haven't already just check any fuses that sound like they could be related to this issue such as brake lamps, ABS fuse, park lamps and so forth. I want to say I replaced my abs one but I'm not positive. Maybe Cereal Killer will chime in and tell ya since he had the same issue
Old 01-12-2011, 07:46 PM
dipsherry's Avatar
dipsherry
dipsherry is offline
fuse number 14 its a 20 amp just look on your fuse panel...its labeled abs/rwal
Old 01-16-2011, 11:36 AM
Ram_King's Avatar
Ram_King
Ram_King is offline
and if it isnt the fuse what else would it be? any ideas?
Old 01-16-2011, 06:37 PM
usranger80's Avatar
usranger80
usranger80 is offline
the speed sensor on the rear axle I replaced mine and it was fixed.
Old 02-06-2013, 05:19 PM
myliftedram 01's Avatar
myliftedram 01
myliftedram 01 is offline
New Member
I have a 2001 Dodge Ram 1500 4X4 my ABS light and brake light keeps coming on and my speedometer is not working . my speedometer only works when ABS light and brake light is off. Any ideas??
Old 02-06-2013, 05:35 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,273 Likes on 3,020 Posts
This post.
Old 02-06-2013, 05:37 PM
myliftedram 01
New Member
Ok awesome was it easy to do? Do I have to open the rear end to replace it?
Quick Reply: Brake and ABS light came on!
