help!!!! before the snow! look
Old Jan 11, 2011 | 01:03 PM
97ramnj's Avatar
97ramnj
Default help!!!! before the snow! look
Are the Dana 60 and Dana 44 CAD housings interchangeable? My shift fork is shot and were going to get a ton of snow and I need 4wd. Does anyone know if there interchangeable?
Orrrrr does anyone in NJ have a front Dana 44 laying around they'd wana sell me the CAD out of ASAP today!
Old Jan 11, 2011 | 02:04 PM
Sheriff420's Avatar
Sheriff420
Your best bet to find one today would be to hit a junkyard.
Old Jan 11, 2011 | 03:28 PM
99dodge318's Avatar
99dodge318
i pretty sure they are the same, the shift fork in the d60 i think is steel vs cast in the d44
Old Jan 11, 2011 | 03:40 PM
zerocool8891's Avatar
zerocool8891
pm sent
Old Jan 11, 2011 | 03:55 PM
gipperkid's Avatar
gipperkid
I thought both shift forks were cast and only steel forks were aftermarket.
Old Jan 11, 2011 | 04:21 PM
97ramnj's Avatar
97ramnj
I'm at the.junkyard now.and can't get.it.off. I couldn't get my Dana 60 cad To fit in the 44
Old Jan 11, 2011 | 04:36 PM
PurplDodge's Avatar
PurplDodge
Throw a few sandbags over the rear axle and you wont need 4WD.
Old Jan 11, 2011 | 05:03 PM
Which one you trying to get off? On the donor truck, or yours? There is only four bolts. Though, they do tend to like to break. (major pain in the rear.)
Old Jan 11, 2011 | 07:33 PM
VEETEN's Avatar
VEETEN
It looks like the 94-01 Dana 44 and 94-99 Dana 60 CAD share the same parts.
That is the shift fork and collar.
Dana changed the 60 in 00-02 and even in those years the collar was different based on BOM (bill of material) I'm unsure of the fork being different within this 00-02 period.
Quad shows the different parts based on year.
The 00-02 info I got from Dana/Spicer
They all share the same cover between years though.
Old Jan 11, 2011 | 09:28 PM
offroadgearhead's Avatar
offroadgearhead
My cad actuator pin is bent so I rearranged the snap rings and forced it into 4wd full time for the snow down here. Not sure what part of your fork is shot, but that may be a quick solution, took about 15 min.
