Back with a new interesting problem
Old Jan 17, 2011 | 12:01 AM
  #21
paintball31390's Avatar
paintball31390
YES! haha, so whats normal psi?
Old Jan 17, 2011 | 12:03 AM
  #22
matty675's Avatar
matty675
6 psi MINIMUM at idle
Old Jan 17, 2011 | 12:09 AM
  #23
paintball31390
ok thanks again
Old Jan 17, 2011 | 12:11 AM
  #24
anything over 10 pounds at idle, when fully warmed, is 'acceptable'.... from there, about 10 PSI per 1000 RPM is standard. If it peaks around 40 pounds or so, that's fine.
Old Jan 17, 2011 | 12:21 AM
  #25
paintball31390
shouldn't my Chilton repair manual say recommended PSI levels of the oil?? I can't seem to find it in the book
  #26
nope. It won't tell you. That is one of those things the manufacturers rarely give hard and fast numbers on.
Old Jan 17, 2011 | 12:22 AM
  #27
matty675's Avatar
matty675
haynes does
Old Jan 17, 2011 | 12:26 AM
  #28
paintball31390
hmm alright then thanks for the numbers =) I will be trying this in the morning
Old Jan 17, 2011 | 06:41 PM
  #29
paintball31390
Ok guys, got the mechanical gauge on no problem, but when I went to start the truck it wouldnt turn over so I popped the hood and saw a small amount of smoke leaking from the air filter housing, I took off the air filter housing and more smoke poured out from it. This is what I found, I assume the black isn't good... but I dont know what would have caused it to smoke. http://twitpic.com/3r0aja
Old Jan 17, 2011 | 07:36 PM
  #30
Big Guz's Avatar
Big Guz
mine only does this when it's low on oil. I'm sure you checked this though. right?
