t case swap
Old Jan 15, 2011 | 02:15 AM
warlord79's Avatar
warlord79
Default t case swap
ok I have a 97 1500 5.9 auto 4x4 and the chain is slipping can i use a t-case out of a 5.2 5 speed 1500 ?
Old Jan 15, 2011 | 09:54 AM
what year?
Old Jan 15, 2011 | 12:09 PM
matty675's Avatar
matty675
i beleive you'll need a '96 or '97
Old Jan 16, 2011 | 10:46 PM
warlord79's Avatar
warlord79
the truck it came out of was a 97 but it looks like it has a elc speedo I thought mine was a cable drive.... mine is a canada export
Old Jan 16, 2011 | 11:15 PM
matty675's Avatar
matty675
nope yours has a VSS just like the one you want to swap with. should bolt right up, no problems
Old Jan 16, 2011 | 11:36 PM
95RAM360's Avatar
95RAM360
actually.....my truck is a 95, and i just changed my t-case, and the case i swapped it with is apparently a 97 from the records i recieved, and i have no problems....
Old Jan 16, 2011 | 11:50 PM
crawlin95's Avatar
crawlin95
i pulled one out of a flooded 2001 for thirty bucks and all i had to do was swap the internal shifting plate took maybe 30 minutes and i got a chance to check everything out on the inside and make sure she was ok. but any t-case 97 and earlier will bolt right up. but if your gonna jerk the t-case you might as well just swap to a 241 out of a 3/4 ton or a 1 ton they are built alot better and come with a six pinion planetary instead of a wimpy 3 pinion in the 231. the 241 as a whole is way stronger and will bolt right up with no issues.
Old Jan 16, 2011 | 11:57 PM
241 is longer is it not? Giving some issues on driveshaft fitment? Not to mention output spline count?
Old Jan 16, 2011 | 11:59 PM
crawlin95's Avatar
crawlin95
nope out put spline count is the exact sam and length is the exact same ive got a spare 231 and 241 sitting in my shop right now i can measure.
Old Jan 17, 2011 | 12:01 AM
OOoooooo, that would be nice if it was a direct swap. Would be a great upgrade for the half tons.
