Trans ???
Old Jan 19, 2011 | 10:30 AM
Shellys4x4's Avatar
Shellys4x4
Default Trans ???
Hi guys. So I thought 5th gear was out on my truck. I took it to the mechanic and ge said the truck only has 4 gears??? Really? A big truck like this. It's a 96 2500 5.9. Anyone else heard of this?
Old Jan 19, 2011 | 10:33 AM
matty675's Avatar
matty675
4spd w/ overdrive.... so yes, simply put, 5 gears.
is it overheating?
Old Jan 19, 2011 | 10:34 AM
Erm..... what does the shift **** say? I wasn't aware that the 2nd gens came with any other trans than the 5 speed.......
Can you stir the trans to where fifth gear SHOULD be?? I suppose it is possible that the trans was swapped out at some point......
Old Jan 19, 2011 | 10:37 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^That would be correct if she has a 5 speed manual.
What matty said would also be true if she has a auto.
Although, I DO think its 3sp with overdrive. Making a 4 sp auto.
I may be wrong though.
Old Jan 19, 2011 | 10:39 AM
Shellys4x4's Avatar
Shellys4x4
No doesn't over heat. Truck runs great. The shift **** is a after market one. When I got it, I thought fifth was out so assumed it needed replaced. The reason why I thought is because when you go to put it where fifth normally is it acts as if you are putting it in N
matty675's Avatar
matty675
yea, is this an auto or manual? autos are 4spd w/ OD
Old Jan 19, 2011 | 10:41 AM
matty675's Avatar
matty675
all manuals were 5spd
Shellys4x4's Avatar
Shellys4x4
It's a manual
dodge dude94
Its a 3sp, damnit! (the 46RE)
The 46RE (Fig. 1) is a four speed fully automatic
transmissions with an electronic governor. The 46RE
is equipped with a lock-up clutch in the torque converter.
First through third gear ranges are provided
by the clutches, bands, overrunning clutch, and planetary
gear sets in the transmission. Fourth gear
range is provided by the overdrive unit that contains
an overdrive clutch, direct clutch, planetary gear set,
and overrunning clutch
Old Jan 19, 2011 | 10:42 AM
Shellys4x4's Avatar
Shellys4x4
Okay so fifth is out
