Budget Lift
Old 01-30-2011, 05:59 PM
PutThtPed@lDown's Avatar
PutThtPed@lDown
PutThtPed@lDown is offline
Default Budget Lift
Hey guys, just recently bought a 98 1500 4x4 Quad Cab. I'm lookin to lift it as much as possible for as cheap as I can. Hopin to keep it under say 4-500 if possible? I've found a few coil spacer and add-a-leaf kits for real cheap but they dont usually go more than 3", anyone have links to a taller cheap lift?
Another question on the topic, what does it take to install a body lift? Can it be done at home with a normal set of tools and a jack?
Thanks for all the help.
Old 01-30-2011, 06:07 PM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
the reason that the cheap kits dont go over 3in is because around 3in you will need new contoll arms
you also can put in v10 or CTD coil springs and gain 2+ in's
Old 01-30-2011, 06:18 PM
PutThtPed@lDown
I'm thinking about doing a 2" Susp lift by rough country with the new nitro shocks, and then a 3" perf. accessories body lift for 5" overall, that'd be enough to clear 35's right?
Old 01-30-2011, 06:33 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Should be.
Old 01-30-2011, 06:41 PM
Twisted Metal's Avatar
Twisted Metal
Twisted Metal is offline
The words "cheap" and "lift" shouldn't be used together.
Old 01-30-2011, 06:53 PM
matty675's Avatar
matty675
matty675 is offline
i PERSONALLY HATE body lifts! anyhow, if you want cheap, get blocks for the rear, front will require LOTS of drop brackets
Old 01-30-2011, 07:09 PM
TheBigRedOne's Avatar
TheBigRedOne
TheBigRedOne is offline
You don't have money for a lift but you have money for the tires? That doesn't seem right to me.
Old 01-30-2011, 07:21 PM
99dodge318's Avatar
99dodge318
99dodge318 is offline
i bought my 3'' leveling kit off ebay for $60, and i run 35'' tires with no problem, unless i try to flex a little
Old 01-30-2011, 07:30 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
How about this. Save the money you have, and when you can get a quality spring/spring lift with good shocks, control arms, and track bar instead of buying cheap spacer lift crap. You and your truck will be very happy with that.
Haha, whats the point of a lift if you cant flex it?
Old 01-30-2011, 07:55 PM
PutThtPed@lDown
Sounds right to me, already bought the tires and rims for it. Ultra wheels and 35" m/t tires, so now im tryin not to break the bank on a lift cause theres a whole lot more i wanna do to er.
Quick Reply: Budget Lift
