Door will not open GRR
Love the forum, I got a 99 club cab I think that is what you call it and the passenger rear door will not open. I took the door handle out and the panel to have better access. The top pin works great but the bottom one is not releasing. I have pried on the lock itself, soaked it in PB Blaster as well as the bottom of the door just above the rocker panel. Any idea's on how to get the bottom to release?
I have been at this for 3 days now and I was going to bend the bottom of the door up but then I thought I better not.
Also anyway to adjust the passing gear cable?
Thanks,
Kev
Thanks,
Kev
In this thread you will find the factory adjustment for the TV cable. Then you can follow the other thread to modify it if you wish.
https://dodgeforum.com/forum/2nd-gen...-in-trans.html
And if you do a search here on DF, you will find other people with the same problem with the rear doors and maybe the solution.
