beefys back, and better than ever!
Old Feb 21, 2011 | 11:15 AM
  #41
beefythedodge's Avatar
beefythedodge
Go go gadget upper control arm! Passenger side control arm stretched an inch and she's gonna be sittin pretty! Gonna install that, and get going on driver side. Finally ccoming together.
Thanks sherif, I am loving the way she's lookin.
Old Feb 21, 2011 | 11:16 AM
  #42
dodgeram07's Avatar
dodgeram07
very cool,
i wonder if you could sleeve the upper c-arm and make it adjust
edit damn i type slow
Old Feb 21, 2011 | 11:54 AM
  #43
beefythedodge
Dodge, I am sure you could on an s10, but not a 6500 lb truck. Plus I am going to put the shock tabs on upp c arm, so I need it super f-ing strong. Lol.
Here's a pic of pass side all assembled, and at ride height!. Lookin sick.
Old Feb 21, 2011 | 01:40 PM
  #44
beefythedodge
She's sittin high, runnin straight and smooth! Lovin life in that fl sunshine.
Old Feb 21, 2011 | 01:53 PM
  #45
dodgeram07's Avatar
dodgeram07
wow looking good
Old Feb 21, 2011 | 03:31 PM
  #46
beefythedodge
Thanx! She rides great, and zero rub. Gotta lift of the rear now to level er out. Gotta cool design for my shock. Def stay tuned for that.
Old Feb 21, 2011 | 10:09 PM
  #47
beefythedodge
Anyone ever had any trouble with trailering with lift blocks in the back? I am thinking of putting 2 inch blockss in the back to level it out, but I pull cars on trailer a lot and don't wanna mess that up.
Old Feb 21, 2011 | 10:19 PM
  #48
dodgeram07's Avatar
dodgeram07
i dont think you will have any problems with towing with blocks
factory 4x4 dodges came with 3in rear blocks, maybe go to the junk yard and get them for cheap
or AAL helper leafs or shackles
Old Feb 22, 2011 | 12:33 AM
  #49
crawlin95's Avatar
crawlin95
dont throw a block in there you will start getting axle wrap do a shackle flip its easy and it only cost me the price of 8 grade 8 bolts and nuts. good for a couple inches and you can throw drop shackles which in normal circumstances would lower it but with the shackle flipped it will raise it higher with out any side effects whatsoever.
Old Feb 22, 2011 | 12:47 AM
  #50
crawlin95's Avatar
crawlin95
Just flip the factory bracket and drill two new holes and torch off the access. may have to cut the bed rail in the pic if you dont have a body lift. i really didnt need to but i did anyway just incase i ever decide to pull the body lift off.
