Check Engine Light On
Old Feb 20, 2011 | 07:38 PM
atc250r's Avatar
atc250r
Default Check Engine Light On
CEL came on today. Appears to still run fine. When I did the key trick, I came up with a 3 and a 10, which doesn't make any sense, does it? I'm working 300 miles from home for another week or so, and my ODB-II code reader is there. Any suggestions? Keep driving?
Old Feb 20, 2011 | 08:15 PM
I would try the key trick again..... That really doesn't sound right.
Old Feb 20, 2011 | 08:27 PM
matty675's Avatar
matty675
go to advance or autozone, they'll read the code
Old Feb 20, 2011 | 09:15 PM
atc250r's Avatar
atc250r
Good call. I was actually getting 2 codes. They are 12 and 37. Nothing to be too worried about I don't think. It's 31 degrees below 0 here, so when it warms up a little I'll disconnect the battery for 15 minutes and that should reset the codes, correct?
Old Feb 20, 2011 | 09:19 PM
37 is TCC...... yeah, try the reset when it isn't quite so arctic out......
