synethic vs regular?????
Old Feb 21, 2011 | 09:18 AM
boowish's Avatar
boowish
Default synethic vs regular?????
Alright I have heard all around that synethic is the way to go and some people say otherwise. Im wanting to know what yall think about it and if anyone runs it? I guess you can say I have high mileage I put 10w 30 Catstol thanks!
Old Feb 21, 2011 | 09:40 AM
BAD_SS/T's Avatar
BAD_SS/T
I run synthetic in my Trans Am with a LT1. I have right at 90,000 miles on me ram. And run Castrol GTX 10-30 high milage in it.
Old Feb 21, 2011 | 09:41 AM
Silver_Dodge's Avatar
Silver_Dodge
Syn for the win.
Old Feb 21, 2011 | 09:47 AM
matty675's Avatar
matty675
i thought many of us had come to the conclusion that Syn doesnt have the ability to keep particulate matter in suspension, allowing cmkenna's famous "cajun crust" to bake onto everything in the engine. read this thread
use valvoline or castrol dino
Old Feb 21, 2011 | 10:13 AM
Annihilator_X9's Avatar
Annihilator_X9
Castrol GTX 10w30 is the only oil I use in mine and she runs amazingly smooth.
Old Feb 21, 2011 | 11:07 AM
dodgeram07's Avatar
dodgeram07
dino.
Old Feb 21, 2011 | 11:30 AM
BIGBIRD85's Avatar
BIGBIRD85
i just did the rocker arms on my truck and the heads have NO CRUST on them at all. 120,000+ miles on this motor. i run 10w30 valvoline.
the original motor ran for 187,000+ miles and when i took it apart it had LOTS OF CRUST AND CRUD!! i ran castrol syentic 10w30 full synthetic for the last 100,000 miles of that motor. i change my oil between 3000 and 5000 miles like clock work. when i had to replace the motor it was due to sludge build up in the oilpan and blocked the pickup on the pump. ill never use synthetic oil again!
Old Feb 21, 2011 | 12:06 PM
matty675's Avatar
matty675
so, there you have it! these engines don't like synthetic and werent made for it, so dont use it!
Old Feb 21, 2011 | 02:12 PM
tweeker909's Avatar
tweeker909
Bought this worked hard work truck little less then a year ago cheap with a horriable ticking and a loud knock. Have done 4 oil changes with Amsoil 10/40 the tick is gone and the knock is quieter. 2X SYN FOR THE WIN.
Old Feb 21, 2011 | 02:27 PM
'07 Dakota R/T's Avatar
'07 Dakota R/T
I am using Mobil 1 full synthetic in the '07 R/T and in my daughter's '03 Turbo Cruiser. I noticed an immediate improvement in performance on the R/T when this oil was installed. It seems almost effortless for the truck to start and accelerate. I use Valvoline MaxLife synthetic blend in my '03 Dakota and '03 Durango(both 4.7s). I also just put it in my daughter's '02 Grand Cherokee(4.0). I like the synthetic, and if it is changed at around 5K, I don't believe crusting or sludge will be an issue............
