Sound like a T-case problem???
#31
Remove it from the front axle first, then angle the shaft as far as you can to the passenger side , with a bolt at the 3 O'clock position. Put the t-case in 4 wheel drive, THEN break the bolt loose. do NOT take it out yet, just crack it loose. Do that for all four bolts, then remove them.
#33
Ok, just took off the front D/S and the 2 u-joints look like they are starting to go bad. They bind up sometimes when rotating them. I drove it down the road and it 65mph with the front D/S off of it and it still was making the same sounds. I also put it in 4wd and it did not make sounds while going low speeds like it did before with the D/S on.
I am now starting to think that the noise is coming from the front axle. It is mainly on the Drivers side where the noise is coming from. Any ideas now?
#34
#36
well, I went to the dealer today because the snap ring that they gave me was way to big. So i went to see why they gave me the wrong part. Turns out that they gave me the right part for the t-case that came original factory in the truck. When the trans shop put a used t-case in the truck from when the previous owner had it, instead of putting back in a 231 t-case they installed a 242 t-case.
Anyone know if this would make any difference? I dont think that the noise is coming from the t-case, but also now wondering if since they put a different t-case in it would that cause any damage/problems in the front axle/diffs or with the transmission?
#37
Some info on the 242.
Actually, doesn't look like such a bad plan...... If the t-case isn't causing the noise, I would leave it in there, and take advantage of the versatility.
#38
what doesnt look like such a bad plan?
