9.25 ram 1500 rear question.
Old Feb 23, 2011 | 09:01 PM
Buellstunter's Avatar
Buellstunter
Default 9.25 ram 1500 rear question.
Does anyone that has rebuilt the chrysler 9.25 rear know if the adjustment collars for the carrier bearings need to be locktited to stay in place one set, or just tap them tight to set them. thanks.
Old Feb 23, 2011 | 11:42 PM
nolazach's Avatar
nolazach
I'm currently rebuilding a 9.25... Just upped the ratio..
I'm not sure of your question though..
Are you talking about the bearing retainers held in place by the four large bolts?
Or are you talking about the part that you adjust through the axle(or the holes on either side of the differential?) If the latter, I think its just tighten them tight, not sure of the torque off hand because I don't have the special tool, I just use a screwdriver.
I was kinda curious about this part myself, though...
Old Feb 24, 2011 | 05:28 AM
Buellstunter
Yep, talking about the latter. I to used a screw driver to back mine off. can't seem to find any info about the adjusters anywhere. guess i'll put some blue loctite on and tap them tight to set them.
Old Feb 25, 2011 | 11:55 AM
nolazach's Avatar
nolazach
Yeah my question about my rear end went un-answered too. I guess a lot of people here don't mess with them.
Old Feb 25, 2011 | 05:02 PM
Buellstunter
I hear ya. plenty of people have done it on here. thought we might get some help.
Old Feb 25, 2011 | 05:14 PM
Most of the folks on here that have re-geared their diffs paid someone else to do it.....
I have done gear setups before, but, not on a dodge rear end....
Old Feb 25, 2011 | 05:21 PM
nolazach's Avatar
nolazach
Yeah, nest time, I'm paying someone; a couple of hundred bucks is worth saving the headache.
By the way, I had the adjuster tool made, No way I could get 72ft-lbs sticking a screw driver in a hole...
Old Feb 25, 2011 | 06:09 PM
Buellstunter
Did you have a socket welded to the other end to put the torque wrench on it? I was reading somewhere on here the ring gear bolt torque is like 110 ft lbs. I just torqued mine last night and the spec. was only 75 ft lbs. did you run into anything like that?
Old Feb 25, 2011 | 08:33 PM
resin113's Avatar
resin113
Here is a link that I posted a little while back.. I since have rebuilt three rearends... If you have any other questions feel free to ask and I will answer the best i can...
https://dodgeforum.com/forum/2nd-gen...e-rebuild.html
Old Feb 25, 2011 | 08:45 PM
BadHab1t's Avatar
BadHab1t
hell most of us paid to have it done, i have a degree for gears drives and mechanisms as part of my electro-mechanical major...., and i still paid somebody...cause labor was 250 out the door...4x2...
