fan clutch ?
Old Mar 6, 2011 | 04:24 PM
lumpydump's Avatar
lumpydump
Default fan clutch ?
hey guys i have a squeal up front of motor . i just replaced water pump,timing chain and a new serp. belt and new tensioner last month . i was wondering if a fan clutch would make a squeal sound or maybe its another pully like the acessory pully its hard to tell where its coming from any thoughts?
edit : its loud when starting at first and a little quiter when warmed up
Old Mar 6, 2011 | 04:52 PM
Reggie220's Avatar
Reggie220
Is the squeal consistent or vary depending on rpm's?
Old Mar 6, 2011 | 06:00 PM
lumpydump's Avatar
lumpydump
its loud at idle and more quiet when rpms are up but its always there
Old Mar 6, 2011 | 06:57 PM
PurplDodge's Avatar
PurplDodge
With the motor off, spin the fan with your hand. If it squeaks, the fan clutch is your problem.
I just replaced mine with one from NAPA. Its $70 and made in the USA.
Old Mar 6, 2011 | 08:16 PM
dodgeman52's Avatar
dodgeman52
just take the fan clutch off and see if the noise goes way but dont run it long with the fan off
Old Mar 6, 2011 | 08:21 PM
PurplDodge's Avatar
PurplDodge
Why go through all the trouble of taking it out when you can just spin it?
Old Mar 6, 2011 | 09:04 PM
lumpydump's Avatar
lumpydump
the fan has a little wiggle in it not much dont know if thats normal or not but i took off the shroud and the fan and started it up there was still a little squeal that looks like its coming from the acessory pulley question can i just oil it or should the pulley be replaced and if i have to replace it who carries one?
thanks for the help
edit : the pulley i call acessory pulley is the one in the middle that runs nothing you know the one that you have take off cuzz theres a hidden bolt behind it when doing my water pump and t chain question ? is that called idler pulley? thats all i can find at napa and autozone online.
Old Mar 7, 2011 | 10:23 AM
Yep, Idler pulley. Just replace it.
Old Mar 7, 2011 | 10:35 AM
jeremey78's Avatar
jeremey78
Sometimes you can narrow it down a little by putting a small amount of grease on one side of the belt and then run the engine. If the sound goes away it narrows down a few of the pulleys...since some pulleys run on the flat side of the belt and some run on the smooth side.
However, I have been having the same issues and have replaced all pulleys except for the alternator and AC...I am still having a squeal...I think it is my AC.
Old Mar 7, 2011 | 03:01 PM
PurplDodge's Avatar
PurplDodge
Have you checked the torque on the harmonic balancer bolt and crank pulley bolts?
