for around $800 i can bulid a mega-viper tranny with the help of PATC. i think that will be the route ill go. it has been a week and i miss my truck!
Yea, thats the more efficient way to go when dealing with anyone is to do the work yourself. But as for me, I find it hard sometimes to do a tune-up, let alone dig into a transmission. One day I am sure that I'll have to something with my tranny (its starting to shift hard and slips occasionally). I think I'll end up dropping the pan and changing out the filter. I may try and check the solenoid and adjust the bands, but I need to look up on how to do that properly.
Thanks to dodge forums and all of the knowledgeable forumites, I feel like I am able to tackle some of these things that I thought I'd never do.
check valve will be gone this week. i have a deeper pan i was going to put on the other one so i will put it on this one. ill order me a cooler and external filter. any suggestions?
The best external coolers have an electric fan that will cool the fins regardless of the truck moving or not. You'll need to write that one in though, and you might want an in cab switch to turn it of in the winter months.
If you go passive cooling, get the biggest one that will fit.
