P0140 code and no power? After installing RR TB and airgap??
Old 03-14-2011, 12:50 PM
dodgeramit_10's Avatar
dodgeramit_10
dodgeramit_10 is offline
Unhappy P0140 code and no power? After installing RR TB and airgap??
So I just finished the install of RR, 52mm TB and hughes airgap, Started it up and gave it a lil while drove it down the road I have no power " I did manage to break my kickdown cable but that shouldnt matter for off the line." I'm just dumb founded and pissed, what did I do wrong or is it just because its running to rich that I dont have power? Any suggestions would be nice please. The code says its a 1/2 O2s staying on center WTF does that mean? just long term for running to rich?
Old 03-14-2011, 12:54 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,225 Likes on 2,975 Posts
O2 sensor code shouldn't effect the way the engine runs, it is whining about the post-cat O2. Staying on center means it isn't doing anything at all... so, probably a failed sensor. (or it isn't plugged in tight?)
Is the engine running smooth? Can you get it going fast enough to hit O/D, and TCC lockup? If you can, is the engine STILL smooth? Got power in the higher RPM range?
Old 03-14-2011, 01:00 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
What is the code # ? And did you bother to check the cat or do anything with your exhaust?
Old 03-14-2011, 01:34 PM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
i was going to type my thoughts, but this works better
http://www.obd-codes.com/p0140
but if you got a problem with a o2 your truck is going to run rich, computer thinks is better to run rich then lean, which it is,
Old 03-14-2011, 05:58 PM
dodgeboy1979's Avatar
dodgeboy1979
dodgeboy1979 is offline
did you reset your computer after all your installs? The comp may take time to relearn all the new components and adjust.
Old 03-14-2011, 09:34 PM
lastrights's Avatar
lastrights
lastrights is offline
hmm i broke the cable on my throttle body too. i dunno man, is it making any noises ? there is no power whats so ever ?? did you by any chance mess up your firing order ?
also make sure none of the injectors are leaking ! also did you uses the fuel bypass hose that came with the kit. make surre that is snug
Old 03-14-2011, 10:45 PM
dodgeramit_10
Im getting more and more power each time I start the truck again, im going to buy new 02 sensors if that doesnt fix it im ganna have to pull the cat off idk how it could get plugged but it might have. As far as the bypass hose goes no I didnt know were it went and my injectors dont seem to be leaking. I went to get a new hose and no dealer has ever heard of it. I need help bad mowing season is coming and this thing needs to be running top notch.
Old 03-14-2011, 10:55 PM
HeyYou is offline
I think lastrights is referring to the hose that goes from one side of the fuel rail, to the other. Dealer probably won't be able to get that for ya.......
lastrights's Avatar
lastrights
bypass hose is the long plastic hose that came in the kit that goes to the back of the fuel rail connects to the 2 .
Old 03-14-2011, 11:10 PM
dodgeramit_10
That actually fits that hose how lol. Or would any hose work? Can I just pull the old one off and put that one on?
Quick Reply: P0140 code and no power? After installing RR TB and airgap??
